A Little Repair, OS 55
This OS engine has been in 3 crashes now. First 2 no problem. This last one, though, resulted in engine damage. Broken muffler and crankcase. The engine was new with low hours. So the decision was to rebuild or buy new. I elected to rebuild. I purchased a new muffler and crankcase. BTW, Tower sells 2 E3071 mufflers. Buy the one for the GGT10 engine. It is lower priced, has the pressure tap and fits this engine. The rebuild was simple and easy to do. The engine is ready for the test stand.
Paperweight on the left side, new engine on the right.
Looks good, did you replaced the bearings? they may have damage from the crash and they are cheap anyway.
they can feel smooth when turning but when axially loaded feel rough or notchy.
Greg
Greg
No I didn't replace the bearings. They really looked good and rolled good. I guess when I run it on the test stand I will find out if it was a good or bad idea.
My Feedback: (66)
yes Should have changed the bearings as of late the OS ones dont last long. Also on that broken case dont throw it away as it is still good. I have glued in many carbs with JB weld and held up for many years. In fact better than the screws that hold it in. If ever need to remove the carb a little heat does it.
Thanks for the tip on JB Weld. I was thinking of using JB on the muffler. Now I'll give thought to the carb.
I have not had time for the engine run. I have a GGT10 on the stand. Have to do another run on it then put the 55 on the stand. Will post results.
Darn, I was hoping to sneak by on the JB muffler repair. Oh well I'll look at plan B.
I did the last run up on the gas engine. I removed it from the test stand and installed the 55 on the stand. Hopefully tomorrow I will see how it runs.
The engine run was good to go. The engine started right up. It idled smoothly and powered up to full throttle ok. No unwanted vibration. No unusual noise. Ran it up to operating temperature. Then I checked the torque on the head bolts and back cover bolts.
I mounted on the engine on the airplane mount then installed the mount on the plane. I need to get this plane airworthy and flying again.
