Securing muffler to 4-stroke engine
I have an OS .95 4 stroke with an "in the cowl" muffler adapter. The engine, muffler, and adapter are all mfg. by OS. The joints are engine to adapter and adapter to muffler. Both joints have the "tightening sleeve" that screws down tight to hold it all in place.
But, no matter what, it keeps coming loose and rattling around inside the cowl.
What can I use to positively secure it but still be able to remove or adjust when desired. I've tried "blue" silicon gasket sealer; still works loose.
Any suggestions?
Any suggestions?
TX
Here's a tip. With the cowl off, run the engine long enough to thoroughly heat up the muffler. Then torque the jam nuts against the muffler and head or any intervening adapter. Be sure to do it when the exhaust assembly is hot. When it cools off it will be much tighter. Basically torqueing while at room temperature or cooler, is allowing the assembly become loose when it gets hot. By doing tightening while hot gets you past that element. Never had a problem with the muffler coming loose again.
