Prop Question
I have run both and personally like the throttle response of the 11.5x4. The 12.25x3.75 is a heavy prop.
Depending on how strong your .46 is you might want to try a 12x4. I have not tried this prop, but have read on RCU where some people get better response out of it than the 12.25x3.75.
If you want high thrust, but also to retain a reasonably good speed, get a Bolly, or an APC 11x6, or an 11.5x6.
It will get 13,500-14,500 RPM and will make enough thrust to pull a 6 lb. plane vertically.
Speed will be close to a 10x6 at higher rpm.
You may need to lengthen the pipe/header, to get it into tune.
