2 Stroke engine help
Old 02-22-2004 | 12:11 PM
Default 2 Stroke engine help
Hello, I need some help on the low end needle adjustment setting and where is a good place to start? The motor is an os max .25! Any help would be greatfull thanks!!!
Old 02-22-2004 | 05:24 PM
Default RE: 2 Stroke engine help
You should get it started if you adjust the air bleed screw to cover half the hole.
If it sounds rough and quits idling after a while, turn the screw out 1/4 of a turn and try again until it idles well. If it dies when you hit the throttle, turn the screw in 1/4 of a turn.
I don't have experience with old engines like the Max .25, but this method works well with LAs and FPs, and their carburettors are similar. Hope it helps.
Old 02-24-2004 | 09:20 AM
Thank you very much!
