Brass type for piston liner
Old 06-18-2002 | 01:31 AM
Default Brass type for piston liner
Hi to all:
I am new in this group and this is my first question wich is the best brass composition for to make piston liner for ABC type engines
Ruben
Old 06-18-2002 | 02:58 AM
Have you considered aluminum?
Old 06-18-2002 | 05:37 AM
My Feedback: (31)
Engine manufacturer's expand considerable sum's for R&D to find the right mixture of metal for all the components of a model engine. I seriously doubt you will have a positive experience with off the shelf brass/aluminum or what have you for the purpose of machining your cylinder/sleeves. You would also want to plate this component. Nickel plating is rather common as is chrome.
Again the metallurgy involved is substantial... The materials used for cylinders/pistons/rings/crankcase's are dissimilar by design. The materials and components thereof is most likely a mixture of metals for a given component part...
LOL
