Prop driver/hub
Old 04-18-2004 | 04:04 PM
Luftman's Avatar
Default Prop driver/hub
Hello all, was wondering if anyone knew of a manufacturer that makes 1/4" (crank diameter) prop drivers (prop hubs) that are about 10-13mm thick and about 25mm in diameter?? The one I want will be a cone and washer type--WITH NO NOTCHES--DAMN OS...LOL
The engine is an .40 aurora and all of the replacements I've come across have not been smooth on the back side (stupid ridge around the edge). The GMS .40 looks exactly like the one I need, but its 5/16ths -- i think (im using tower info on this).
Below is a link for what im after (im almost sure tower has nothing for me as I've ordered wrong stuff thus far).
http://www2.towerhobbies.com/cgi-bin...?&I=LXEGT8&P=7
Thanks for any and all replies.
Im lost.
Old 04-18-2004 | 04:16 PM
Default RE: Prop driver/hub
Call Fox Mfg. with your specs and see if they can help.
ZB
