perry pump????????????
Old 06-09-2004 | 09:39 PM
serge760's Avatar
Default perry pump????????????
i have no space to mount my perry pump on my engine,can y mount the perry pump on my firewall????????[sm=confused.gif]
Old 06-09-2004 | 10:06 PM
Default RE: perry pump????????????
Serge:
If it's the shaker pump the closer the better. If it's the one operated by crankcase pressure on or right behind the firewall is ok.
Bill.
Old 06-09-2004 | 10:56 PM
JohnVH's Avatar
My Feedback: (38)
I have mounted them to the firewall before, and one to the engine mount.
Old 06-20-2004 | 01:09 AM
amram's Avatar
Hello Bill
As you are familiar with the Perry regulator may I ask you:
I have a MOKI 1.35 with a regulator installed as written in the book.
The engine quit on me after 2-3 minutes of operation. The quit occure while throttle is in 1/4 at no acceleration or idle.
Any idea or other links to where I can ask.
Amram
Old 06-20-2004 | 08:58 AM
Amram:
Perry pumps:
http://www.perrypumps.com/
Regards your in flight engine failure, almost without exception it's a heat problem if the carb adjustment is otherwise OK. This can be air flow, too large a prop, or just too much nitro in the fuel.
Bill.
