10 to 15 size engine help needed
Old 07-09-2002 | 12:49 AM
Default 10 to 15 size engine help needed
I will be purchasing a 10 to 15 size glow engine in the near future to power a 72'' motor glider. This engine will spend a lot of time at the low throttle settings. This does not need to be a high performance engine. A good Idle with smooth transition is more important than maximum power. I guess user friendly is what I'm looking for. Any suggestions would be greatly appreciated. :idea:
Cvan
Old 07-09-2002 | 01:15 AM
Default 10-15
If weight and power isn't a major issue, get a OS, TT or Magnum plain bearing .15.
If you want more power, the Norvel is a great little performer but the muffler on the .15 sucks- a heavy clip-on type.
I've got an AP yellow jacket .15. It's powerful and light with schnuerle porting, BB's and rotateable rear exhaust.
At a little over 50 bucks, it's the best value of them all.
Hope this helps!!! Kirk
Old 07-09-2002 | 10:54 AM
Default Reply
Thanks for taking the time to reply boomstriker. I will take a look at the AP's.
Cvan
Old 07-09-2002 | 11:43 AM
Old 07-09-2002 | 04:57 PM
I run a OS 15FP in a Sig Wonder. I bought it new about 4 yrs ago and this thing is about as reliable and predicatable as you can get. It starts easy and has a air bleed carb which shut off because I want to make sure the engine dies when I'm on final. I guess this engine is no longer available but I'll bet there are still some around. Not sure if the LA is as good.
Old 07-09-2002 | 11:39 PM
J-3
Default MAGNUM .15 DBLE BALLBRG
I have the MAGNUM 15 with a double ball bearing crank and this is one sweet engine that makes great power and has a great throttle transition. I definetly recommend this one....Brian
Old 07-10-2002 | 01:01 AM
Default Great help
My first engine purchase when I got back into RC in 1985 was an FP-35 and I think it is still going. If the LA's are as good it, should make a great motor for this project, but I wanted to check with you guys first. I live in the middle of no where and can't talk to the guys at the field. No club. Thanks for everones input. It really helps.
Cvan
Old 07-10-2002 | 01:06 AM
Banned
My Feedback: (-2)
I've got a new magnum .15 in the box,but it's missing the collet for the crankshaft.I have had no luck finding one,does anyone know where to get one?
