Webra 160 bearings solution
Old 01-11-2005 | 07:55 PM
Default Webra 160 bearings solution
Hi,
I would like to know if somebody have use the de ceramic rubber sealed bearings from boca bearings in the webra 160?
If so, which were the results?
Has somebody found stainless steel bearings for this webra some where?
If so, which were the results.
Best regards,
Patricio Ch.
Old 01-12-2005 | 02:30 AM
DarZeelon's Avatar
Default RE: Webra 160 bearings solution
Patricio,
The bearing sizes that you need are:
Front 10x26x8 mm
Rear 20x42x8 mm
Contact Paul at [link=http://rc-bearings.com]RC-Bearings[/link].
His bearings are the same, but his prices are 55%-70% lower, for both steel and ceramic bearings.
You will get nothing for paying someone else more... Unless you opt for WIB bearings.
You can probably get these bearings in any of the better hardware stores in Santiago.
Old 01-12-2005 | 06:00 AM
Thanks for the info Dar, could you explain me what WIB bearings means please?
It`s true that in Santiago´s harware stores exists the replaces, but they don`t last much time , just like the originals.
What I need is to upgrade the bearings quality to resist nitro corrosion.
Best regards,
Patricio Ch.
Old 01-12-2005 | 06:05 AM
OK, now I know that wib is a swiss bearing factory.
