Trainer & Os 70 Surpass
Old 10-04-2002 | 12:45 AM
My Feedback: (13)
Default Trainer & Os 70 Surpass
WILL OS 70 SURPASS POWER A 60 SIZE TRAINER WITH AUTHORITY?
THANKS
Old 10-04-2002 | 02:49 AM
My Feedback: (7)
Default 70 Surpass
The 70 Surpass will work fine on your trainer, but why would you want to use an expensive engine to power your trainer. The chances are any engine on a trainer is going to take a great deal of abuse. I think you would be better off to use a plain bearing, inexpensive two stroke engine. Just my opinion, take it for what its worth!!!
Steve
Old 10-04-2002 | 01:42 PM
MinnFlyer's Avatar
And depending on your plane, it may fly it, but it won't have much authority. A 70 would be a better match for a 40 size plane.
Old 10-04-2002 | 02:13 PM
Always had a problem with authority, myself.
Old 10-04-2002 | 05:54 PM
Matt Kirsch's Avatar
My Feedback: (21)
I'll tell you that my OS 70FS Surpass flew my PT-60 with plenty of authority. Most ARF .60-size trainers are much lighter than the PT-60 I built, and generally recommend .46-.60 2-strokes.
Don't worry about using such an expensive engine in a trainer. Unless you crash full-bore, nose-first into something hard like asphalt or a large rock, the engine is the last piece that gets damaged on an R/C airplane. Most of the time, the engine hits soft dirt and the airplane crumples around it. It's a great, friendly engine that will give a beginner far less grief than some of the lesser two-strokes.
