hpi engine substitutions?
Old 07-29-2005 | 10:52 PM
Default hpi engine substitutions?
can you put a cen .46 genesis engine on a hpi savage 25 and if so what mods are needed and if not what is the most powerful engine you can put on the savage with no mods
Old 02-27-2006 | 06:54 PM
Default RE: hpi engine substitutions?
im at the same stage with my savage do you know how to determine the size of a motor if there is no markings on block
Old 02-27-2006 | 08:44 PM
proptop's Avatar
My Feedback: (8)
I believe you need the extended chassis kit to put the .46 in a Savage.
I have installed a Mach .28 and an SH .28 (same basic engine ) a Wasp .27 and several Fantoms...the only thing you might have to do is open up the holes in the (purple ) motor mount plate just a little.
The Mach .28 works well...and all the stock clutch parts will fit. Get one with an SG shaft.
Old 02-27-2006 | 08:48 PM
proptop's Avatar
My Feedback: (8)
Bryce...if all else fails, you can just measure the bore and the stroke and figure it out from there.
What brand of engine is it?
Old 02-28-2006 | 03:10 PM
do a little research on that cen 46 engine and se if you still want it that bad. It is the biggest piece of sh.t I ever had. That goes for the whole cen genesis. do not believe that 5 horses claim, it is total bull..it. I have owned a genesis and a savage. The savage with a picco 26 blew the genesis away. Go to cen racing forum and look up my previous posts on the genesis and its engine. Do your self a favor and get a good 26-28 engine instead.
