Welcome to Club SAITO !
#5526
RE: Welcome to Club SAITO !
Dave,
To answer your other questions, the pressure tap on the muffler is pretty universal, but you may wind up getting one from Horizon Hobbies anyway, unless your LHS is very well stocked. I've never measured it, but that's most likely a metric thread.
As for the 'fuel' fitting on the bottom of the engine, that's really a drain for crankcase oil, which is a byproduct of the engine. Fit a piece of fuel tubing to it to drain the oil away.
I have a Saito .82 and really enjoy it. Lots of different suggestions for prop sizes. Just stick with the manual that WR just sent you and you'll do OK.
Bob
Bob
#5527
I just acquired a Saito FA80GK.
I noticed a tap in the backplate. Is this tap for the crankcase vent or is it the muffler pressure tap ?
My Saito 72 & 82 have taps in the front of the engine to vent the excess oil to the outside. This tap on the backplate is the only tap/vent on the engine.
Campy:
The FA-72 and FA-82 engines have a plastic back plate, for this reason as well as better lubrication to the cam and tappets, the crank case vent was moved to the front of the engine. The FA-80GK isz the older design with a metal back plate, and it still has the vent in the rear. To the user there's no difference in the front or rear location of the vent.
Bill.
Bill.
#5529
TX
William
I got this from tower tips. It says when breaking in your car or truck engine, it is not a good idea to let it idle. Letting it idle for a tank or two of fuel will break the parts in at a low temperature and will cause it to lose compression when you open it up full throttle. I know we don't fly car engines, but Saito says to run it for ten minutes not over 4000 rpm. Is this why the Saito have lite compression?
#5531
WRM:
The engines in 99.44% of the R/C cars have tapered bores and no piston rings. They have to be gotten to running temperature as quickly as possible, both in break-in and normal running. Otherwise they will wear rapidly. This is also true for ABC type tapered bore airplane engines.
Saito engines are ringed engines, break-in is quite different, ten minutes at 4K rpm wont hurt them at all.
Bill.
Bill.
#5532
TX
William
This I can understand about the car engines. Now why do my Saitos feel like they don't have much compression when turning it over by hand?
#5533
WRM:
As a quick guess you're turning the engine with the throttle closed. Unlike a two stroke that can back fill the cylinder with air through the exhaust port, all the air in a four stroke has to come through the carb. Prop the throttle open and feel the difference. Post your comment, might make some others believe also.
Bill.
Bill.
#5534
TX
William
Yes I was turning the engine with the throttle closed. Yes you can feel the difference. But my old OS feel stronger, but it is older.
#5535
FL
Yes, all of my Saito engines will seem to have no compression with the carb closes. But open the carb and feel the difference. Back filling the cyclinder with pressure will fool you compared to a two stroke. Fuel it and fly.
#5536
Heaven on a stick!!!!
Ran my 170R3 in on the weekend and was I (and the collected spectators) impressed at how ridiculously easy it is to start. This is truly a case of read the manual and do what it says. Put three litres through it and it settled to a nice 8,200 RPM WOT with a 16X8 MAS prop running 10% nitro. Should gain a few hundred more in flight. What impressed most was the reliable really slow idle without glow support.
Now I am thinking I shall have to save frantically to buy a second for a BIG twin project. Tigercat or Beaufighter perhaps?
You have just got to love Saito's
TC
TC
#5540
Now that my hands have thawed out I have another question on my Saito 80GK.
Braved the cold today and got the engine running, FINALLY. The engine runs out well - 10,350 with an APC 13x6 on 15% fuel. Burble in transition, but that is most likely fine tuning the carb.
My question:
My 72 and 82 run fine with the high speed needle open 2 - 2 1/4 turns. This 80GK needs to have the high speed needle open 4 3/4 turns AND be extremely wet before it will start. Temperature was 37 degrees, humidity about 75%.
I realize every engine is different, but this seems excessive to me.
Suggestions ?
Thanks.
My question:
Suggestions ?
Thanks.
#5542
My Feedback: (102)
Camp, if that is an older Saito .80 it could very benefit from a spraybar upgrade for the carb.
http://www.horizonhobby.com/Products...rodID=SAI80144
#5546
My Feedback: (16)
You have to select the individual components from this list.
http://www.horizonhobby.com/Products...arts%20Listing
some of us buy our rings from.... Frank Bowman. He manufactures repro and current piston rings for our modeling needs. He can make standard and Dykes type rings. If he doesn't have the ring you need in stock, you send the piston and cylinder and he will make it then. prices are around $9.50. His work is of the finest quality.
Frank can be reached at:
Frank Bowman
1211 N. Allen
Farmington, NM. 87401
505-327-0696 (6 pm to 9pm MST weekdays)
Email: [email protected]
And our bearings from RC bearings or Boca Bearings
http://www.mcintoshcentral.com/rc-be...8fa5c4c427f08e
Some people reface the cam followers if necessary
Frank Bowman
1211 N. Allen
#5547
My Feedback: (7)
IN
ORIGINAL: William Robison
Are you Saito fliers? Tell me yes and I'll add you to the list.
Bill.
Bill.
I have a .82 GK in a H9 Twist,
another .82 in a Seagull Harrier 3D,
a 1.50 in a Dave Patricks Ultimate,
and a 100 awaiting it's next plane.
#5548
NY
Can anyone who's gotten a stack mounted to a 100 (or similar) give me any kind of a link or a size or a part number or anything that points to where you got that o-ring, tubing, or whatever you used?
I've been messing around with o-rings, tubing, and everything else I could find but I can't get anything to fit well.
Thanks!
Thanks!
#5549
My Feedback: (16)
Are you talking about an O-ring between the intake extension venturi and the carburetor?
I went up town to the hardware store and the lady let me select one (I had the engine with me to compare sizes) from her assortment box. But I bought a half dozen.
In the past, I have used an old intake manifold O-ring that was originally between the head and the intake manifold.
