Welcome to Club SAITO !
Old 03-09-2007, 06:35 PM
  #6576
w8ye
My Feedback: (16)
w8ye's Avatar
Default RE: Welcome to Club SAITO !
The timing mark for the crankshaft is to have the piston at top dead center
Old 03-10-2007, 08:01 PM
  #6577
dhal22
I have acquired an older saito 1.20. after difficulties in running it i took it to the field were there are several experts on 4 strokes. the net net of the is they recommended sending it in for service. does anyone here know where that is? thx, david
Old 03-10-2007, 08:05 PM
  #6578
RVM
Horizon Hobby
ORIGINAL: dhal22
Old 03-10-2007, 10:12 PM
  #6579
blw
blw's Avatar
David- what kind of problems?
Old 03-10-2007, 10:36 PM
  #6580
dhal22
the exhaust valve rocker arm was obviously over gapped upon removing the cover. after 3 four stroke guys took a look, got the gap back down to .0002-.0003 the piston was clicking on the valve during manual rotation. we removed the plug. i am describing this the best that i can (i am not an engine expert). the consensus was that the cam had been removed and reinstalled 1 notch off. 1 guy recommended readjusting it myself, the other 2 guys said saito service was well worth the money. thx in advance, david
Old 03-10-2007, 10:44 PM
  #6581
dhal22
adding to the above post. after the valve adj., then the piston was hitting the exhaust valve. seems to be why the gap was so large to begin with. in other words watch what you buy off of the big auction site. david
Old 03-11-2007, 07:41 AM
  #6582
SigMan
My Feedback: (21)
SigMan's Avatar
I READ A REVIEW WHERE THE GUY BROKE-IN HIS SAITO 180 WITH A 16*8 PROP THEN SWITCHED TO A 18*6 PROP AFTER IT WAS BROKEN -IN. WHY DID HE DO THIS? CANT YOU BREAK-IN THE MOTOR WITH THE PROP YOU INTEND TO FLY WITH?
Old 03-11-2007, 03:39 PM
  #6583
davewallace
My Feedback: (29)
Sigman,
During breakin there is somewhat more friction and heat buildup, so reducing the load on the engine will help it run cooler.
Dave
Old 03-11-2007, 06:47 PM
  #6584
SigMan
My Feedback: (21)
SigMan's Avatar
thanks dave..
Old 03-11-2007, 10:47 PM
  #6585
PE2fan
My Feedback: (8)
PE2fan's Avatar
4 blade propeller for a 125a??
Anyone have a suggestion for a 4 blade prop for the 125a?
I am putting it in a P47 and think the 4 blade would be sweet.
Thx
Micheal
Old 03-12-2007, 11:39 AM
  #6586
Kmot
My Feedback: (24)
Kmot's Avatar
w8ye: Jim, where did you get those photos of the Saito cut-aways?
Old 03-12-2007, 12:36 PM
  #6587
w8ye
My Feedback: (16)
w8ye's Avatar
I got them from the Saito in Japan site.
They didn't have one of the 325. All they had are in my Gallery if you are interested.
Old 03-12-2007, 02:06 PM
  #6588
Kmot
My Feedback: (24)
Kmot's Avatar
Oh yeah, I copied them all already. I had been to Saito Japan before but not seen these. Thanks!
Old 03-12-2007, 02:15 PM
  #6589
freeonthree
freeonthree's Avatar
Personally, I would rather see 2 strokes cut in half...
Old 03-12-2007, 02:34 PM
  #6590
SigMan
My Feedback: (21)
SigMan's Avatar
whats the best of the shelf fuel for saito's ?
Old 03-12-2007, 03:08 PM
  #6591
Bipe Flyer
Bipe Flyer's Avatar
ORIGINAL: freeonthree
Would that make them single strokes?
I used to run all 2 strokes, until I got a few 4 strokes, and now I doubt I'll buy any more 2 strokes - unless they're 1/2A. Now, if there were 1/2A 4 strokes...
Old 03-12-2007, 03:46 PM
  #6592
Kmot
My Feedback: (24)
Kmot's Avatar
A band saw can work wonders!
Old 03-12-2007, 07:23 PM
  #6593
rajul
Moderator
My Feedback: (58)
rajul's Avatar
Wow, talk about inner beauty!
Old 03-12-2007, 07:58 PM
  #6594
w8ye
My Feedback: (16)
w8ye's Avatar
YES, ISN'T IT THOUGH
Old 03-12-2007, 08:05 PM
  #6595
RVM
We need a Saito with an overhead cam. It's gotta be more efficient and lighter than a pushrod set up.
Old 03-12-2007, 09:23 PM
  #6596
blw
blw's Avatar
Jim,
A cutaway of one of the radials would be very beneficial. Too bad they don't have one.
Old 03-13-2007, 12:23 AM
  #6597
Jerryballs
My Feedback: (19)
Gentelmen,
I am not a member of Club Saito but use Saito's in just about everything I have...a 91, a 150, a 180, a 100. (I tell you this hoping I can get some advice without having to research the entire thread.) In keeping with the Saito's I like so much, here is my question. I have a 300t (single carb) and want to use it in a 1/3 Balsa USA Cub. The specs call for 50cc and up and the 300t is 50cc...but does the "twin" cut into the amount of power it will provide? Thanks in advance for any thoughts.
Old 03-13-2007, 06:35 AM
  #6598
JNorton
JNorton's Avatar
Jerry,
I don't know about the cub but it fly's a 1/3rd scale Sig Spacewalker just fine. I wouldn't think you would have any problem.
John
Old 03-13-2007, 07:48 AM
  #6599
Dave :^)
Dave :^)'s Avatar
Hi Jerry,
welcome to club Saito, don't worry there is no membership fee! The 300T should be fine as the 50cc recommendation is probably pointing in the gas engine direction, and although a twin makes slightly less urge than a single, a glow makes more urge than gas. Unless you want to 3D your Cub I'm sure you'll be fine! Hope you understand what I'm trying to say, I'm not the best at putting thoughts into words.
Dave :^)
Old 03-13-2007, 09:19 AM
  #6600
w8ye
My Feedback: (16)
w8ye's Avatar
The cub has a large wing area and light wing loading. They accept a broad range of power plants and normally need much less power than what you would think given the size and weight of the airframe.
The OS FT300 twin has been used in the 1/3 scale Cubs for many years. So the 300 Saito will be a great choice for this plane
