Welcome to Club SAITO !
#9601
CT
RE: Welcome to Club SAITO !
Well, I put the new bearings in my .45. All went well untill I put it all back together. I'm looking for ideas to fix this problem. I don't know why, but the crankpin is hitting the backplate when I tighten the backplate. At first I thought it might be that the rear bearing wasn't seated all the way, since it isn't flush with the case, but that wasn't the problem. I pulled off the cam gear and spacer and re-installed the crank and there's plenty of room, so the cam gear and spacer are holding the crank too far back. A thicker gasket might work, maybe tripple the thickness of the stock one, or somehow shaving the length of the spacer. I guess the front bearing's inner race is either a little thicker than the original, or the bearing seated in deeper than the original. The crank hits enough to freeze up when the backplate is tightened, but it will turn, with rubbing, if I loosen the backplate screws 1/4 of a turn. Has this ever happened to anyone else?
#9604
AK
ORIGINAL: w8ye
It shouldn't get much worse.
#9605
ORIGINAL: AKFireMedic
Well, I suppose I expected it wouldn't get worse. I was just wondering if running the new fuel will clean it out at all or if I need to get in there and clean it manually? Any ideas?
ORIGINAL: w8ye
#9607
MT
HI, I'm new to this site and just getting back into the Hobby (R/C Airplanes). So - reading some of the very informative and interesting post leave me with all kinds of questions.
For starters, and anyone tell me where you can buy a Cline Regulator? I have searched every why I know how on the internet and cannot come up with a sales source. Help?? Thanks.
#9609
Bill Robison suggested soaking the cylinder upside down with, I think, acetone to dissolve the deposits. I almost suggested doing that with glow fuel overnight, and then reinspect. I'm just not 100% sure Bill was using acetone. You could also use Dawn Power Dissolver for about an hour and see if it works. I don't know about how well it would dissolve carbon deposits yet.
#9610
MT
Thanks for the information. Took me right to the Cline web site. I just bought a Saito 180 I am planning on putting in a Giant Super Sportster. It appears the fuel tank will be a little higher than desireable. I'm hoping the regulator will solve that problem is it does turn out that way. But another question. It looks like you should be about to just turn the entire intake pipe, carb and all around 180 degrees if you needed to to get it even with the tank. Has anyone ever done that?
#9611
Hi Guys,
I missed this forum... for some reason, the updates stopped coming. Glad to see that it's still alive and well. Just getting back on here, so I've missed a lot over the past month or so.
Bill Robison used to tell about a place called RC Bearings, but I'm not sure that I have the correct website. The site that I get to seems to have its URL for sale.
Can anyone tell me if RC Bearings is still active, and what their URL is?
Bob
Bob
#9614
OH
Hi I have used a product Made by Stihl( the chainsaw company) to remove Carbon. I belive it was called EDT(It's been a while) I used it on a 4stroke and was pleased with the results. I didn't have to remove valves, just soaked for around 20hrs with ex valve open.
#9615
Hi We3R/C,
My prolblem is a little bit different. Turned my plane into a lawn dart. Buried it up to the firewall, no exageration.
Thanks for the tip on that EDT though. I wish I had known about that a few months ago when I rebuild an ancient Saito 120. Carbon city! I think I know a place that I pass on my way to work that might have Stilh products. I'll stop in there and check them out.
Bob
Bob
#9616
VA
So anybody want to be the guinee pig? Check this stuff http://www.ferret.com.au/c/Avanti-Ch...system-n668721 Seems it has to be hot tanked but the chemicals are safe and biodegrade. Also has corrosion and rust inhibitors .
#9617
CT
Rear bearing was bottomed. i think the old front bearing may not have been bottomed. When I put the crank in without the cam gear and spacer, it went in all the way, so the rear bearing wasn't interfering. I wondeer if the spacer was maybe the wrong one. I took about .005" off of the spacer,and it all went back together fine. I'll run it when I get some good weather.
#9618
About the Cline regulator, is it okay to use fuel with castor in it? I understand that the YS engines can't use castor because they have a diphram, and the Cline also has a diaphram. (gets gooed up or something)
Ernie
Ernie
#9619
AK
Hmm, good info. It still has great compression so I really don't want to disassemble it just to clean it up. I might try to soak it in glow then run it and see if most of it blows out.
#9622
Good Cline info guys. Sounds like even if you did run castor and then were going to let it sit for a while that you could run some synthetic through it right before winter sets in.
Thanks loads,
Ernie
Thanks loads,
Ernie
#9623
NJ
Hey guys
I broke the fuel nipple on my saito 72. I looked on horizons site but it looks like you have to buy the carb body too? Does anyone know of one i can use?
#9624
TX
TX
