Plz , Help me adjusting an engine
Hi
I have and MDS 0.25 engine whicch doesn't want to be adjusted .it accelerates great , but at full thrttle , it runs for 10 seconds and then goes down. I opened the high needle valve till 4.5 turns and the problem persists.
Plz help me what to do.
thx
thx
My Feedback: (14)
ORIGINAL: shreifali
Hi
thx
Hi
thx
Look at the muffler pressure nipple and ensure that it is open. Sometimes flashing will cover the orifice and cause a problem similar to yours. Good luck.
Ed Cregger
HI
I use A3 OS glow plug and 9x6 propeller and 15% powermaster fuel.
I Guess the orifice of my fuel tank needs to be wider?
what do usay?
thx
what do usay?
thx
It sounds like your engine is trying to run a fuel with too much nitro in it. Back down the fuel to 5% or less nitro and change the prop to a 9-4 until the engine has a quite a bit of time on it so it is fully broken in. Those 2 things should help with your overheating and pre ignition problems.
My Feedback: (12)
15% does not sound not too high, and a 9x6 prop should not cause over heating with a needle out so much. It sounds like a fuel draw, or air leakage problem. Here are some questions, and some things to check:
1) Is this a new engine or was it working ok and now it's not? If it was ok, what happened just before it started running bad? As you screw the needle out, does the engine show any signs of getting rich or does it stay at a high speed? Watch the fuel line closely while the engine is running to see if there are any air bubbles.
2) When it stops is it hot, or relatively cool? If it's hot, that's a sign that it's too lean. If it's not hot, it must be another problem.
3) As has been suggested, make sure the pressure fitting on the muffler is clear (you have connected the muffler pressure to the tank, right?), put a piece of tubing on it and confirm it's easy to blow air through it. Do the same with the tank, attach a fuel line and blow through it to confirm there are no obstructions. Also try plugging one of the tank outlets and blow through it to confirm the tank can hold pressure.
4) Attach a piece of fuel line to the carb and screw the needle all the way in. While blowing through the fuel line, screw the needle out. As the needle gets further out, it should be easier to blow through the fuel line. If it doesn't you may have an obstruction in the needle assembly.
5) Ten seconds is enough time for the fuel to start foaming. Confirm that the tank is well padded.
6) Check the fuel lines for holes, and confirm that the clunk has not been pushed to the front of the tank.
7) Confirm that the carb is firmly seated on the o-ring.
8) Sometimes air can leak past the threads of the needle, making it difficult to make the engine rich. Cut a piece of fuel line short enough that you can slip it over the threads of the needle assembly. Unscrew the needle, put the fuel tubing on and screw the needle back on.
Sometimes when a fuel tank is just filled, the engine-tank pressurizing couldnt work at beginning until some fuel spending to make enough pressure established.Try this: After starting engine give half throttle and quickly plug and release the exhaust outlet with finger but not to stop the engine, sure..This will make enough fuel come to carb.After 2 or three such attempts try to give full throttle.If you can,its better to try this at full throttle without stopping engine.I had to do this several times on 2 TT42 GP.
