O.S. or Duratrax Engine?
Old 12-07-2005 | 08:06 PM
Default O.S. or Duratrax Engine?
im trying to figure out what engine i should get for my Nitro Evader ST. im deciding between the .18 Duratrax rotary carb or the O.S. .18 CV-RX w/11J Rotary Carb. wHICH ONE DO YALL THINK I SHOULD GET? iF NIETHER, WHICH ENGINE SHOULD I GET THAT WILL FIT AND WORK?
Old 12-07-2005 | 08:12 PM
w8ye's Avatar
My Feedback: (16)
Default RE: O.S. or Duratrax Engine?
The OS is a better known name. Duratrax is just a proprietary name, who knows who makes it.
Old 12-07-2005 | 09:56 PM
proptop's Avatar
My Feedback: (8)
I'll have to take a look, but I think the DuraTrax engine might be an O.S.? (could be wrong...and I'll edit this statement if I have to after I check it out )
I do know that the DuraTrax monster truck ( the Warhead ) I looked at the other day has an engine made by Supertigre, the G27CX (how 'bout that one Jim?!)
edit: yep...the DTX .18 is made by O.S. so, you wouldn't be gaining anything by "changing" engines.
Check out the car and truck forums and see what some of the popular replacement/upgrade engines are...
Good luck
Old 12-09-2005 | 07:07 PM
i know i wont be gaining anything. its because my motor is burned out.
thank u
Old 12-10-2005 | 01:02 AM
DarZeelon's Avatar
Gymnast,
Whichever engine you select, do the break-in of your next one, using the method described [link=http://www.rcuniverse.com/forum/Tapered%2DBore_Engine_Break%2Din_%2D_Upgraded/m_1850473/tm.htm]here[/link].
In a couple of threads, modelers that run car engines, wrote their engines last about three times as long, before needing a rebuild, when using this method, rather than the "extra rich" break-in the hobby shops "recommend"...
Old 12-11-2005 | 10:40 AM
I have a Duratrax Torq 16 engine with about 20 gallons through it. My kids punish the snot out of that poor engine. I think it is a good one since I have had yet to replace anything but the recoil pull starter assembly. Another good one is the Fantom.
