Glpw Plug Threads
Old 12-31-2005 | 07:25 PM
My Feedback: (22)
Default Glpw Plug Threads
Does any manufacturer make a glow plug that is 1/4 X 28 instead of 1/4 x 32?
Old 12-31-2005 | 08:24 PM
Flyboy Dave's Avatar
My Feedback: (21)
Default RE: Glpw Plug Threads
I don't think so....every one I've seen is the same, except for the Cox .049
glow heads.
FBD.
Old 12-31-2005 | 08:35 PM
w8ye's Avatar
My Feedback: (16)
Though I've never seen one, I think some of the Nelson plugs have 11/32-32 threads. They only fit Nelson engines.
Look at the plug on the left.
Enjoy
Jim
Old 12-31-2005 | 09:41 PM
Actually the Nelson Plugs fit any engine head that is drilled and tapped for them. (Actually there may need to be a little more machining to give clearance around the hex.) I have a Cox TD 09 head with a Nelson plug. I'm thinking about getting a couple of other heads drilled and tapped for them.
Old 12-31-2005 | 09:54 PM
w8ye's Avatar
My Feedback: (16)
I thought the Nelson sat in a pocket like a Turbo plug? That the taper on it's end rested against a seat so there were no sharp threads exposed?
Old 01-01-2006 | 01:05 AM
My Feedback: (85)
Bad news sounds like someone retapped their cylinder head to 1/4-28 instead of getting the right tap. Well am i right? probably not. But anyways in case anyone needs a 1/4-32 tap Micro Fasteners sell them. There are probably others also.
I myself have never heard of 1/4 28 glow plugs but then again i've been wrong once or twice before
Dennis
Old 01-01-2006 | 01:15 AM
w8ye's Avatar
My Feedback: (16)
You can send your head to:
Clarence F. Lee MFG Co.
10112 Woodward Ave.
Sunland, CA 91040
818-352-3766
He can put a helicoil in to convert back to 1/4- 32? its in the $12 range I think?
Call and ask?
Enjoy,
Jim
Old 01-01-2006 | 07:52 PM
Uh-huh, Clarence Lee can probably install a Helicoil for around $12, as w8ye claims. You might can also buy a new head for only a little more, depending on the engine. Compare prices first.
Dr.1
