another 2 stroke vs. 4 stroke thread
AR
I have a GMS120 2 stroke that turns an APC 17X6 around 9300 rpm on ys20-20 fuel.
That is right in the 4stroke rpm range and with similar power to that size 4stroke.
It revs quickly and runs great.
It would hover my 10lb funtana easily.
Only problem is that it sounds like a 2 stroke.
Larry
Larry
Torquewrench- if you want that suck, squeeze, burn, blow thing we should switch to turbines!!!!! 8*P I've been tempting 2 guys at the field a lot about getting into that. No luck so far.
Sport Pilot- it is a sad situation if an engine has to limp around at 8K for noise limitations when it is supposed to buzz at 15K. Another reason for 4 strokes!
ORIGINAL:
Dirt Bikes use 2-strokes, why don't Harleys?
4 stroke engines are clearly better than 2 strokes, especially when using gasoline. Less fuel usage, more reliability, and longer lives.
