cheap tower hobbies plugs
Hello I just did a search for the tower plug but came up empty handed. I want to order some, next time I order from towerhobbies. Are they any good,(os 8 clone??) sure are cheap
then I will stock up on them, os plugs you say? Is it like the great "os" engines from china? Same or even better than the original at half the price, he he.
Are they EXACTLY the same as the OS plugs ?? I have read that the cheaper tower plugs use less platinum on the element which makes them cheaper, but that they are not as good and dont last as long also. Is this true ?
My Feedback: (16)
They are a little hottor than a OS #8. They are more like a OS #3. I had one in a engine for 100 flights. The only reason for not any more flights was that I traded the engine off. They seem to last a long time.
The only way to tell them from a OS plug is that there is no name on the side. The OS plugs will have a OS 8 written on the side.
no I don`t blow a lot of plugs. I don`t blow a lot of engines either but still like the cheap os clones, same with plugs. Why pay more??
