Perry Pump adjusting
Old 08-15-2006 | 05:08 AM
voodoodb's Avatar
My Feedback: (98)
Default Perry Pump adjusting
Need some help adjusting my pump. If you are looking at the front (nipple end) of the adjusting screw, do you turn clock-wise or counter clockwise to increase pressure? I understand that counter clockwise increase pressure, but just unsure of which end to look at to get the counter clockwise rotation.
Old 08-15-2006 | 05:27 AM
JettPilot's Avatar
Default RE: Perry Pump adjusting
Screwing it IN increases the pressure. Screwing it out decreases it.
JettPilot
Old 08-15-2006 | 07:42 AM
Sport_Pilot's Avatar
In is clockwise.
Old 08-15-2006 | 11:27 AM
Planeclothes's Avatar
ORIGINAL: voodoodb
No matter how you look at it, clockwise is clockwise and counterclockwise is counterclockwise. So you go clockwise (in) to increase pressure or counterclockwise (out) to decrease it.
Old 08-15-2006 | 01:11 PM
voodoodb's Avatar
My Feedback: (98)
From Conley who makes the Perry Pump, who says in decreases pressure, out increases pressure.
Doug,
Turn the large hex nut, with the pressure nipple, counter clockwise to increase the flow. You can unscrew it until you see the edge of a black “O” ring. That is the maximum flow. Remember, for best results the pump should be mounted parallel with the wings.
Best regards,
Gary L. Conley
Old 08-15-2006 | 01:20 PM
Ok, he said pressure so I assumed this was the VP-30. Now Mr. Conely is quoting from the VP-20 manual. So which is it? The VP 30 wich regulates flow or the VP - 30 which regulates flow?
Old 08-15-2006 | 09:27 PM
I guess he wasn't talking about the VP-30...[:@]
