Norvel glow plug problem
Old 07-17-2002 | 06:44 PM
Default Norvel glow plug problem
How many times did you use it before. Because just like all other glow plugs, they wear out after time. I've never had a problem with them before
Old 07-19-2002 | 02:54 AM
gcb
sd2002,
What kind of fuel have you been using? Norvel explains that some fuels for larger engines are not good for the Norvel because the Norvel engines run too cool to burn off some of the additives used for larger engines.
They recommend their fuel and also have a list of fuels recommended for Norvel engines. I use Norvel 15% for mine.
George
