*** CLUB SUPER TIGRE ***
Old 12-09-2015, 02:25 PM
  #1851
tailskid
My Feedback: (34)
tailskid's Avatar
Got a buddy with a ST 90 and a 'OS' D7 carb...here is a pic of the carb, I don't remember a D7 looking like this....Engine just doesn't like to run....
Old 12-09-2015, 03:15 PM
  #1852
hsukaria
that's because they took out a good carb and replaced it with junk!!!
Old 12-09-2015, 03:35 PM
  #1853
1QwkSport2.5r
1QwkSport2.5r's Avatar
I'd put the SuperTigre carb back on it. They work amazingly well if you read the instructions on tuning them.
Old 12-09-2015, 03:44 PM
  #1854
1QwkSport2.5r
Originally Posted by jeffie8696
He may be out of town on a trip
That may be, I haven't gotten a reply yet. That's okay - to move ahead, I found a parts engine with a good carb on it. I should have that engine in a few days - it's coming from the other side of the country.
Old 12-09-2015, 04:17 PM
  #1855
tailskid
My Feedback: (34)
tailskid's Avatar
I'll see if he still has that carb...there must have been a reason he took it off to begin with.
Old 12-09-2015, 05:21 PM
  #1856
downunder
downunder's Avatar
Just to show you never can tell with ST carbs, this is the carb from my NIB ST S45 ringed. Same idle needle as mentioned but a similar style barrel type main needle.
Name:	ST S45 carb.jpg
Old 12-09-2015, 06:42 PM
  #1857
1QwkSport2.5r
My S90K carburetor has the same brass features on the needle valves as your S45 ring engine does, but my other ST engines have different embellishments (if you will). Pictured first is my S90K, GS45/G51, and S29 Carburetors. I have an S45 ring coming in the mail.
ID:	2135120   Click image for larger version
ID:	2135121   Click image for larger version
Old 12-09-2015, 07:03 PM
  #1858
1QwkSport2.5r
Here is a picture of the idle mixture needle from the S40 (19.5mm - too short), and the idle mixture needle from my S90K (26mm - the proper length for the S40 carburetor as well). At some point, someone replaced the needle in this S40 with the incorrect idle mixture needle.
Old 12-09-2015, 07:38 PM
  #1859
edh13
My Feedback: (9)
edh13's Avatar
I never knew there was a CLUB SUPER TIGRE but your thread made the RCU Top 15 on the home page. Thought you guys might like this pick of my ST 60x. Nothing sexier than Super Tigre Serie X with header.
Eric
Old 12-09-2015, 07:41 PM
  #1860
1QwkSport2.5r
That's pretty cool - but I have to ask why the Perry carb?
Old 12-09-2015, 07:51 PM
  #1861
edh13
My Feedback: (9)
edh13's Avatar
It was a pump package option from the vendor available back in the 80's for piped ballistic pattern acft of the day. This was a 'Before' pic...
ID:	2135126   Click image for larger version
Old 12-09-2015, 08:04 PM
  #1862
1QwkSport2.5r
I had a feeling there was a big mouth in the carb and a pump nearby. A lot of folks swap another brand carb in for the ST carb which usually ends up in a downgrade in performance. A big pump carb and pump is a little different story on the right engine. You have a beaut there!
Old 12-09-2015, 08:11 PM
  #1863
edh13
My Feedback: (9)
edh13's Avatar
Thanks.
That was a 30 year old barn-find 'Tiporare' I restored and flew in classic pattern meets for a few years. But as I said, those were 'before' pics. I lost it in Lancaster Calif last summer. And the ST was junked too...
Old 12-09-2015, 08:12 PM
  #1864
hsukaria
That's the Tiporare, isn't it? I want one!!!
Old 12-10-2015, 03:52 AM
  #1865
1QwkSport2.5r
Thanks.
That's a major bummer. Sorry to hear that.
Old 12-10-2015, 06:47 AM
  #1866
FlyerInOKC
FlyerInOKC's Avatar
You got to rebuld that beauty!
Old 12-10-2015, 10:44 AM
  #1867
hsukaria
Thanks.
Tragic!!
Old 12-11-2015, 05:30 PM
  #1868
jeffie8696
jeffie8696's Avatar
I have a Series X 60 for parts or rebuild if anyone is interested. Needs a ring and muffler.
Old 12-11-2015, 08:46 PM
  #1869
1QwkSport2.5r
What do you want for it, Jeff?
Old 12-14-2015, 08:59 AM
  #1870
FlyerInOKC
FlyerInOKC's Avatar
If QckSport passes on it let me know.
Mike
Old 12-14-2015, 10:38 PM
  #1871
jeffie8696
jeffie8696's Avatar
You bet
Old 01-03-2016, 10:53 AM
  #1872
RDJeff
I could use some help finding the bore/stroke specs for all the big Tigres. I've looked all over, but can't find the information. Thanks!!
Old 01-03-2016, 01:24 PM
  #1873
Hobbsy
My Feedback: (102)
Hobbsy's Avatar
http://sceptreflight.net/Model%20Engine%20Tests/
Lower right, lottsa good stuff.
Old 01-03-2016, 04:36 PM
  #1874
RDJeff
Thanks Dave, I'd forgotten about that resource! I actually found an info sheet in the box one of my engines came in, and it lists all of the information I was looking for.
Old 01-10-2016, 08:37 AM
  #1875
1QwkSport2.5r
Has anyone ever tore a ringed ST down to rebuild it or repair it and find the ring gap to be in excess of .010"? I tore an S90 down to clean it up and fix a leaky gasket and noticed the compression was lousy. Checked the ring gap and found it to me .012"!! I have a Bowman ring on hand and the ring gap of it was .0015". Wow that's a difference. I have the main engine parts in an antifreeze bath currently.
