*** CLUB SUPER TIGRE ***
#1876
Has anyone ever tore a ringed ST down to rebuild it or repair it and find the ring gap to be in excess of .010"? I tore an S90 down to clean it up and fix a leaky gasket and noticed the compression was lousy. Checked the ring gap and found it to me .012"!! I have a Bowman ring on hand and the ring gap of it was .0015". Wow that's a difference. I have the main engine parts in an antifreeze bath currently.
#1877
I do have a type of honing brush made of a hard plastic bristle with some sort of ultra fine abrasive embedded in it that I used to break the glaze in the cylinder. It added a nice cross hatch to the bore. With the Bowman ring installed, it's got it's "pop" back that it had last year and it hasn't even been run yet. It should run at least as good as it did before. I use a Jettstream muffler on it (.90 size red).
#1880
I paid $85/shipped for an old S90K that was run a few times on the bench. I'd think $60-75 for a very nice lightly used engine to be reasonable. It takes a fair bit of running to seat the ring in an ST, so if the ring is completely silver in color, it's got at least a couple hours worth of time on it. A black ring is new or nearly new.
#1882
All of my SuperTigres have pinned rings. S29, S45, G51, and S90K. I don't know of any off-hand that don't have pinned rings. I just installed a Frank Bowman ring into my S90K. It's amazing how much better it feels when flipping it over.
#1883
I would imagine they would all have pins . Remember its not a 4st with no openings in the liner . The ring would catch in the exhaust port etc otherwise . I have a mag that shows the ST positions of the pins , there not all the same . Cheers the pope
#1885
Hi there Tim , I was talking about the ST's but its been along time since I looked at that mag . But if Im wrong the pope is willing to be re-educated ! Cheers
#1886
I dont know if ALL ST ringed engines are pinned, but I'd hazard a guess that most are.
I think it would be good information for folks to have that info about piston ring pin locations. Maybe over on RCG in the "manuals" sticky.
I aint mad mad atcha and I wasn't trying to disprove you. You're a good ol' chap in my book!
#1887
do use only the largest fuel tubing and tank hardware available for the ST 3000 ,so you will have no fuel drawing problems
The fuel tubing and tank hardware , for 60 and 90 size ,will not do the job , to feed the big glo engines that are 1.80 or larger
My old ST 3000 ( 1. 80 ) and my Moki 1.80 Need the larger fuel lines to perform as they should ,and they DO !!
Hope that info helps get her done
Enjoy
Enjoy
#1888
Enjoy
Enjoy
#1889
Very average over all performance from these two
My 51 and my old 3000 are real work horses ,and better than they SB ,as the best glo engines are
Like to own a G 90 as it is a light powerful engine ,i think in a 60 engine case ,that somehow i have not yet given a try
The 2300 is interesting to me after this thread
Flying two cycle glo for 23 years , more than most
The OS 75 AX has animal power in this size ,and best for a 60 size airframe ,that i know of
I flew a 75 ASP ( ABC ) with an OS 7D carb for years , on a 60 size airframe , until i bought the 75AX and experienced its performance
The 75 ASPs carb is a copy of the OS 7D carb ,a good carb that will hold up well ,( wore one out after about 200 flights ) but never as good a the OS 7D carb ( that i have 4 of - not for sale )
OSs claim to fame , is they make the best ( air leak free carb ) on the market with the best metal for the task ,which equals great reliability and performance
The 45 ,51 and the old 3000 are better glo engines than they SB ,and those that i have personnal experience handling ,a lot
Enjoy
#1890
The OS 75 has animal power in this size ,and best for a 60 size airframe ,that i know of
#1891
The reason I commented as I did was only in relation to your comment about a 4-stroke and snagging a ring in an open port.
#1892
Its all good there Tim , you know you hold a special place in my heart ! Now back to all things ST . I have just spent 11/2 hrs looking through my mags and I am done ! If I come across it I'll post them for sure . For the Aussies out there it was in the Airborne magazine going back a few yrs so if anyone sees them . Cheers
#1893
Found the power of the ST 60 and the 75 ,to come up short for there size
#1894
I do think the larger glo engines have bigger inlets ,on there carbs
Muffler pressure is needed as well
I used the regular size tubing for that
My larger engines ran great ,set up ,with the larger tubing
#1895
I have never seen a 2 stroke engine with out a anti rotation pin ,,, from glow engines to chain saws to go karts except an abc engine that has no ring,,,,I am 62 and been building and repairing engines my whole life.
#1896
[QUOTE=f16man;12161037]I have never seen a 2 stroke engine with out a anti rotation pin ,,, from glow engines to chain saws to go karts except an abc engine that has no ring,,,,I am 62 and been building and repairing engines my whole life.[/QU I f there is one how the heck do they keep the ring from rotating a tip into a port, and that is almost always a major catastrophe for the sleeve and piston at least....
#1897
According to Frank Bowman's piston ring list, a bunch of the smaller Fox engines don't have pinned rings (.40 Schnürle, 45, 50, 59) as well as some Enyas (6002), and many others. I have a Fox .50 that doesn't have a pinned ring.
#1898
TX
But the presence of the pin begs the question: How much allowance for the thickness of the pin must be included in the end gap of the new ring?
CR
#1899
Well, the reason I asked is that you have to subtract the thickness of the pin from the measured end gap. So, the end gap of the old ring may not be the issue. Could be the old ring is just shot.
CR
CR
#1900
A workaround for engines without a pinned ring was a bridge across the port(s). Some hop-ups include removing the bridge when using a pinned ring to replace the stock one. Removing the bridge increases the flow; replacing the ring with a Bowman pinned ring increases the performance due to improved compression from better sealing rings and and reduced ring blow-by from smaller ring end gap.
