Engines...
ORIGINAL: asmund
He doesn`t need the power of the 91 fx but it is also possible to throttle back a little. Anyway my first recommandation was a light, powerful and cheap engine. Cheap can be good in the beginning to reduce cost of a possible fatal crash.
Around here we run alot of ASP, SC and Magnums and have no problems with them.
And there actually IS a chanse he could go wrong by the 61 fx, or can you absolutely guarantee that it will not peel its nikel??
This is why I mentioned the 91 fx, almost the same weight and identical mounting space, it has a ring and steel sleeve (no peeling, guaranteed
) If the power is not needed just reduse the power on the stick.
I had the first bach of 91`s with bad remote needles which gave me alot of deadsticks, but I DO actually do quite some research and as far as I can tell the problems with the 91 fx has been taken care of, mine too:-)
I guess you are one of them OS lovers, just remeber I too own OS engines, and YS and MVVS and.... I have no brand loyalty really
I guess you are right about them ASP and Magnums from the 80`s but maybe, just maybe things have changed some the last 20 years?
There`s alot of highly respected names in here that are very happy with their Sanye engines from these days. I guess you are right about the LA 65 beeing a great option, it is cheap, more powerful than the 61 fx and much lighter too
I don`t disagree with you on that so take it easy, this is just a hobby and I just gave my opinions about this matter, it might differ slightly from yours, but in general I think we agree on most parts
Oh I forgot, do your own research a little better (you pick on mine all the time) and you will soon find that it was NOT only the 46 fx that was burdened with this peeling problem, also some LA`s, 32 fx`s, 61 fx`s and what not. Most all OS engines with nikel can peel because the very same plating technology is used on them. I don`t have anything against OS, I will just only buy their ringed engines and on top of my wishlist right now is the |120 ax, so there you go[8D]
ORIGINAL: asmund
What more can he ask for or you want other than a lower price?
As it is, O.S. have rationialised ther pricing over the past couple of years so that it's still fair and reasonable compared with western incomes, if still not the cheapest. The price of spares has only become a major issue since the price drop of some of their engines which makes items such as replacement carbs or N/V assemblies disproportionately expensive in comparion with buying a complete unit. Probably the most salient example of this was the ABN liner fiasco of the .46FX, where replacement with a new P&L, gudgeon and clips is simply economically triaged out of the equation. For the record, I have yet to see a failed .46AX liner..and I see a lot of them in ops every other day. O.S. seem to have solved the problem with their new dual coating process. Longevity? Well the engines are made for the U.S market's consumption driven sales model and buying trends.
What I refuse to buy is high probability "maybe it will, maybe it" won't unreliability or outright trash.
ORIGINAL: asmund
Buy ringed if that pleases you. I'm sure O.S. won't mind, and neither will I.
#32
MI
the guy asks a simple question. relies on a simple answer(relatively) without debate and technical b...sh... And what does this site offer......
just give advice on your own true experience. If for some strange chance in this world
that your opinions don't parallel with others......put a cork in it and let it go. help the guy
and be on with your engine ego.
#34
My Feedback: (14)
[quote]ORIGINAL: sigrun
I began buying ASP engines in 1992. None of my ASP engines (all two-strokes back then) had a single, solitary problem and back then I was flying several times a week - long before diabetes knocked me on my Tukkus.
While others in the club were having problems with ASP engines, I had zero. I bought, owned and flew two .12, one .46 and one 1.08 Redhead. All of the carbs worked as advertised. None had rod or crankshaft failures, or any other kind of failures.
I must admit that I am old school when it comes to using castor oil. Back then I was having fuel mixed for me by S&W. It had 5% nitro, half synthetic and half castor oil. Sometimes I ran 5% nitro with all castor oil, depending on the mood I was in and the majority of engine types I was using. I never trust any engine to all synthetic oil unless it is a major brand name, like OS, Enya, Webra, YS, Rossi, etc. Sub brands, like anything Chinese, Fox, Merco or K&B all get a fair dosing of castor oil in the lube package.
Folks showed up at the field with stuck throttle barrels. I told them how to fix them. No, they'd rather whine and cry about buying a piece of junk than fixing it and flying it. I've had new Enya, Fox, K&B and OS engines with throttle barrels that stuck after a while. The fix is simple and easy. I don't have time for whiners.
For me, the Chinese engines have represented true value. Now I am saddened that they are raising their prices to the point that one may as well buy a higher quality brand name engine (NO - not Magnum). Back when the Chinese engines were at one half to two thirds the price of an OS, I bought. I had not bought any Chinese engines for quite a while, until a couple of weeks ago. I bought two Sanye engines (ASP) from Peakmodel in NZ. Their prices were in the buyable range that I established versus OS. Since then, the prices have been drifting upwards. Who knows, it could be the devaluation of the dollar. I don't know and don't care. I'll just buy the higher quality brand names until the Chinese engines fall to their old price point.
Am I brand loyal? No, not really. I'm also not political about buying products. To me, that is idiotic and short sighted. The best way to change a communist to a capitalist is to help their business succeed by not discriminating against them. Conversely, I don't buy their products out of sympathy.
Happy New Year
Ed Cregger
#35
For a trainer, there's a ton of .60 size engine choices out there. O.S. .65 LA or .60 FX would be my first choice if money wasn't an issue, but for the budget conscious, those new Chinese made Super Tigres are hard to beat performance, longevity and overall value wise - they are just a tad harder to adjust than an O.S., but if you quickly llearn how to make mixture adjustments correctly, this is not a problem. A friend recently bought a new Evolution 1.00 and we ran it up last week on my test stand. I was very impressed by the fit, finish and how quickly it broke in. Like an O.S., in minutes it was run in and running flawlessly. The Evolution series of engines are, like the O.S. LA series, aimed specifically at beginners/trainers and come with limiters on the low and high speed adjustment needles. If you can obtain an Evolution engine cheap, there's another option.
