worst engine ever
#201
RE: worst engine ever
ORIGINAL: rainedave
Try an APC 10x6 and see if you do better than my SS40BB:
http://www.rcuniverse.com/forum/fb.asp?m=8345393
The figures in the link above are about right for that engine on 5% nitro. If your SS45 does a little bit better I'd say it's performing fine.
David
David
Don't have that prop on hand, but will get one next week, I'll even match your fuel, 5% nitro and 22% castor? I would expect it to run 12.5K
Though it's an apples to oranges test, plain bearing for me with aluminum piston (ringed), mine is more over square and is C/L.
Yours is rated at 1.2BHP while the ss40 plain bearing C/L is 1.1BHP
What figures do you get with the APC 11x6?
#202
My Feedback: (14)
ORIGINAL: jeffie8696
The problem is that OS engines are so good that we need one to pick on and that is the LA series.
From the tach forum.
I have a nice well used TT GP42 that made the following numbers using an OS .40 size muffler with no baffle (cause that is all I had). On an APC 10X4 15,300 an APC 10X7 11,800. On 15% Magnum fuel and a Merlin red plug. 57 deg temp, 42% hum. 30.3in baro.
My only problem with the OS LA series is their price. It is too high for what else you can buy for the same money, or less. For the same money you can buy a Chinese made ball bearing engine that will eat the OS .40 & .46 LA alive in power production. Then why do I own so many OS LA engines? Nostalgia partly. I cut my modeling teeth on plain bearing engines. Versatility in that you can fly, wipe the model a little bit and throw it in the trunk of your car without worrying about running it out dry or pumping it full of ARO. And last, but most important these days, they make excellent Diesel conversions with their small carburetors and conservative timing.
Besides all of that, engine designs have their own personalities. Some are just flat-out enjoyable to operate. What amazes me is how the LA series of engines vary in operating characteristics from one displacement to another. While the .40 and .46 LA engines aren't all that powerful, the .15, .20 and .25 sized LA's are not slouches in the slightest. I sometimes think that the .40 and .46 were detuned to get the buyer to buy another, more expensive engine.
Ed Cregger
#203
ORIGINAL: Luna_Rendezvous
The engine is rated @ 1.3BHP without mentioning propeller used or at what rpm.
The recommended props are 11x6 to 12x7
Kens said to break the engine in on the 11x6
While I never really expected it to run @ 1.3BHP, not many engines do there rated HP figures but 1.1 to 1.2BHP would have been acceptable for the given purpose.
I fully believe the engine might be a dog relative to others; I am just saying that by expecting those horsepower numbers on big props you might have a lifetime of disappointment.
MJD
#204
ORIGINAL: rainedave
David
David
22% Lubricant, 50/50 castor/coolpower blue
5% Nitro Methane
73% Methanol
Air Density 1.158 kg/m3
Plug Enya No:3
No Muffler
Rpm = 12910 [:@]
Next run with 10% Nitro and 24% Lube...
Rpm = 13100 [sm=spinnyeyes.gif]
#205
Banned
Why are you using/wasting so much oil?
You'd probably get better results if you went down to 18% consisting of 15% CP and 3% castor.
#207
ORIGINAL: XJet
I don't know? Maybe I’m "wasting oil"
I own about 17 model glow engines, none are ABC and one has ball bearings, and none have carburetors, I fly control line which means WOT 100% of the time, none of my engine manufacturers recommend lubricant content under 20% so I guess I'll be wasting lube for a while longer
Oh by the way I bought my first RC model a month ago, and it's a Lecky .... Can’t believe how easy RC is compared control line, you thumb twiddlers need to try the F2B, all stunts done between 5' and 60' from the ground!
