Saito 80GK problem
Saito 80GK problem
My Saito 80GK has had the following done to it:
Valves adjusted to correct clearances and rechecked.
Needle valve/spray bar upgrade installed.
Intake gaskets replaced (part of needle valve/spray bar upgrade kit )
All fuel lines, including lines inside the tank) replaced
All engine bolts double checked for tightness.
The Problem:
The engines surges at 3/4 - full throttle.
My idle is 2550 - 2600 (low speed screw out about 3 1/8 turns ). The idle is not near as smooth as my Saito 72, 82 or OS 52 Surpass.
MAX rpm with a 13x6 APC and Powermaster 15% nitro is 8400 - 8575 rpm. (Should be in the 9500 - 10,000+ range )
High speed needle is out about 2 3/4 - 3 turns.
If this is any help, this particular engine trys to backfire a lot when starting compared to my Saito 72 and 82.
I have a gut feeling the low rpms and the surging are connected (but my gut has been wrong before )
Any ideas/suggestions ?
The Problem:
TX
RE: Saito 80GK problem
Well I had a kind of problem like yours; I bought on EBay a Saito 91 which was very difficult to tune up. After several months of experiencing with it, I definitively decided to change the carb assembly and the needle valve, I could fix the problem cheaper, with only the needle valve, what I found after is that the previous owner changed the original needle valve; of course it partially worked fine but never had the right in the spot point of tune. When I received the new needle valve I was curious and compared both, the old one was a bit shorter and wider, the new one was a bit longer and thinner, I have to say that physically there was a minimal difference but when installed and tuning, Boy what a difference!!.
Normally you open the needle valve 2 and a half turns, then you start to close to get the most rpm, with the old valve I had to open almost 4 turns and there were a big sweet spot between 2 and a half and 3 turns but always erratically, since you are in a similar situation I wanted to share this experience of mine that could be helpful.
Best regards
Alfred.
Best regards
Alfred.
You should be getting a lower idle. Backfiring is from a lean condition. Try richening the low speed needle valve about 1/4 turn for starters to get it rich enough again. Then, fine tune from there if needed. The adjustment is effective up to something like 80% throttle. It will have effect on the high speed setting.
The correct high speed needle valve setting could be anywhere. You can't use a specific amount of turns out to find the right spot.
Correctly setting the needle valves may solve all of the issues with the engine.
edited for grammar
edited for grammar
Hi,
you don't say what fuel you are using, if your '80 is a high compression one you may be using too much nitro.
Dave :^)
Whoops! sorry I see it now, haven't woken up properly!
Dave :^)
