120 webra
Old 10-04-2007 | 09:54 PM
Default 120 webra
Help. I have a new 120 webra and it will not run inverted it has the factory pump. It floods out and fouls the glow plug out. My first time experience with a webra.So if any body can help me i would really appreciate it. Thanks.
Can't Fly
Old 10-04-2007 | 10:06 PM
Default RE: 120 webra
Help. I have a new 120 webra and it will not run enverted it has the factory pump.It floods out and fouls out the glow plug. My first time experince with a webra. So if any body can help me i would really appreciate it. Thanks.
Can't fly.
Old 10-04-2007 | 10:53 PM
Try an "extended tip" glow plug; i.e. an O.S "F"; Fox Miracle; or K&B 4 stroke plug (available from from MECOA).
I have listed the plugs in order of heat range (hottest to coldest). Hangar 9 "H" and Saito SS plugs, similar to the above, may also be suitable, but I haven't any experience with those.
Choose the one that works best in your application.
Many R/C'ers running large 2 stroke glow engines inverted find that putting a 4 stroke plug in (designed for O.S. four strokes) really helps reliability. Apparently the extension on the tip helps ward off oil pooling and snuffing out the coil, which can be a problem at idle ...
Old 10-05-2007 | 07:48 AM
for starters i would not have monted the 120 inverted. i would have side monted it. the glow plugs fiery recomended are a good start. the other thing the people that have inverted glow engines flip the plane over to start them. (crazy) the other thing you could try is onbord glow. if you can get it started but cant keep it running after the glow driver is removed. the other thing is a regulater for the pump. i have a 120 webra with a pump side mounted and runs great. so dont give up. c-crunch
Old 10-05-2007 | 01:23 PM
If properly tuned, orientation shouldn't matter, although it may require different starting procedures to prevent excess fuel from collecting in the engine. Also note that some engines require a bit of time on them before they can be properly tuned. If this is engine is new, perhaps it will get better after it breaks in a bit more.
Just my thoughts......
Old 10-08-2007 | 08:19 PM
I appreciate all the replies an have changed several glo plugs 4 stroke & 2 stroke. I e-mailed webra and thay sayed to put a bypass line across the pump and run the pressure line to the muffler. I did so this evening and same o same o. DON'T KNOW WHAT TO DO?
But i realy appreciate the help.
Cant fly.
Old 10-08-2007 | 08:53 PM
Hobbsy's Avatar
My Feedback: (102)
Put a Cline or IronBay regulator on and then enjoy it.
Old 10-08-2007 | 09:56 PM
and side mount it.
Old 10-08-2007 | 10:55 PM
I AM PUTTING THE WEBRA A SHOWTIME AND IT WILL COME UP OVER THE WIREWALL.I ALL SO JUST BOUGHT A NEW INVERTED MUFFLER. CAN YOU TELL ME WERE TO FIND THOSE REGULATORES.
THANKS A LOTTTTTT.
CAN'T FLY.
Old 10-09-2007 | 07:00 AM
You can get the Cline unit here. Not sure about the Iron Bay.
