Which .46 engine to run inverted?
I need to pick a .46 for a small pattern/freestlye aircraft. The engine will be mounted inverted so I want a reliable engine that will run upside down. O.S , TT ?? Which?
FL
I've had a TT Pro .46 inverted in my WM Mustang for years. No Problem! Had one side mounted in a Super Decathalon with no troubles either.
Why pay more for less?
Hi
A certain engineer working in OS moved to the TT company, and that a TT engine was developed, and I listened.
Therefore, a TT engine looks like OS, and has both high performance.
It is OS if a brand is taken.
It is probably TT if a cost is taken.
kobayan
kobayan
