Go Back  RCU Forums > Glow Engines, Gas Engines, Fuel & Mfg Support Forums > Glow Engines
What are common problems with Moki 1.35?? >
Old 04-09-2003 | 06:25 PM
Default What are common problems with Moki 1.35??
Thinking about a Moki 1.35 for a H9 73" cap, are there any common or known problems with this engine? What is the fuel consumption?
Can you mix your own alchohol and oil for this engine?
WOOD
Old 04-10-2003 | 05:44 PM
Default Good combo
I saw one fly about 3 weeks ago, It was not lacking, it flew great and did everything I coiuld think of except hover. Hope you have as much luck with yours. Moki makes great engines from what I know of them.
Good luck
Im getting the 1.8 for my Cap
Old 04-11-2003 | 12:45 AM
SA Flyer's Avatar
Default Known Moki 135 Problems
Less than 2 years ago I had bought one and found that it would die while in flight usually during the first 5 minutes and usually when I pulled vertical.
On my engine, I think there was a problem with the carb machining where the orifice on the Low Speed Disk and the cat-eye groove on the Drawbar Lock (??) were not really in alignment around mid-range.
Well, I tried everything then and have gotten some modified instructions from the USA Distributor of the engine. So far, I have not succeeded in getting a satisfactory engine run and the engine has been sitting in a box for about 4 months.
This last week I decided to order a Draw Bar Lock part, but the wait may be a while due to it being out of order. If that doesn't work, then I will have to sell something to get an new $82 carb.
The engine is definitely a powerful engine with an APC 16X8 or 16X10 prop on 5% PowerMaster and the OS F 4-stroke.
I am not giving up on it and I suppose that the recently manufactured engines are pretty good now. This because I don't see any posts with users complaining about the Moki 135.
SA Flyer
