Miller RC "Persuader" giant scale starter
RE: Miller RC "Persuader" giant scale starter
Mac Hodges,
Please advise how I order your $20.00 starter switche for a Miller starter using a Sullivan Dynatron starter on 24 volts as pictured in your photo. Thank you.
John Gaspari
[email protected]
561-575-0958
561-371-6632 Cell
John Gaspari
[email protected]
561-575-0958
561-371-6632 Cell
My Feedback: (16)
RE: Miller RC
John,
Just call Mac Hodges at Mac Hodges Hobbies 866-924-9505. He will ship it right out to you. His hobby shop is outside Andersonville, GA at the airport.
http://www.hodgeshobbies.com/home.html
See him use his version of the starter here
http://www.youtube.com/watch?v=S0DxPo5tWGg
This video was taken in front of his hobby shop at the airport
Hi,
Does anyone know how I can get the Miller unit in or to the UK?? I already have the Sulllivan Dynatron starter. I would also like the uprated switch and bracket.
I have tried emailing Mac Hodges, but so far have had no reply. I'm actually in Orlando Florida until Friday if it helps. Payment is not a problem, there are several options open including PayPal.
Best Regards
Mike
Best Regards
Mike
PA
It would probably be best to call him at Mac Hodges Hobbies 866-924-9505.
They will need to know what size spinners are on your planes. Also, I would recommend using a 24 volt battery system (I use two 12 volt batteries connected in series). It's a great starter, and well worth the money. I modified the switch on my Dynatron starter, mounting it on the handle of the Miller starter. It works just fine. I can more fully describe how to do that if you'd like. Good Luck!
Has anyone tried a Miller Persuader / Dynatron combo with the Makita 18v setup?
I have a Fine Design base ordered for my Dynatron:
http://www.afineredgemfg.com/index.htm
I fly both helis and airplanes, and want to use it on my 50cc Yak..
David
David
#32
PA
RE: Miller RC
I was able to use the switch already instaled on my Dynatron starter; I removed the switch from the starter handle, keeping the wiring intact. I then simply taped it to the underside of the handle on Mac's Persuader and it works just fine. The Persuader is an awesome starter at 24 volts! I think it would turn over a car engine!
#33
My Feedback: (16)
RE: Miller RC
I took my Dynatron with the Miller reducer and made it up exactly like the one Mac Hodges has. Two batteries, 24V and all.
I used the same exact switch that he used in his picture, but I put the switch on the other side for left hand use as you push the switch with your thumb. It weighs 17.8 pounds
The switch is this Dorman one
http://shop.advanceautoparts.com/webapp/wcs/stores/servlet/product_Electrical-Switches-Specialty-Starter-Switches-Push-Button-Metal-Dorman-OE-Solutions_5470633-P_N3618D_P|GRP60036_____
I managed to get a couple starts out of the device before the side of the switch blew up.
I then replaced the switch with this heavier Dorman switch
http://shop.advanceautoparts.com/webapp/wcs/stores/servlet/product_Push-Button-Sealed-Starter-Switch-Dorman-Conduct-Tite_25984905-P_N3063A_A|GRP2020A_____
I also added an audio crossover 10 uF non polarized axle lead capacitor from Radio Shack across the switch contacts and so far - so good - we'll see.
http://www.radioshack.com/product/in...ductId=2102481
