25VF and 25VF-DF Crankshaft Specs
I have repeatedly heard that there is a difference between the 25VF and 25FV-DF crankshafts. Does anyone know the actual crankshaft dimensions or specifications. I know the stroke is the same. Is it that the crank pin locations different, either advanced or retarded from one to the other? Or is it the intake port on the crank that is advanced or retarded? or a combination of both. I know that they stamped them differnet. eg VF and VF-DF.
I was under the impression that all timing was acheived thru liner porting.
Bryan
Bryan
RE: 25VF and 25VF-DF Crankshaft Specs
Thanks kweasel for your reply.
I'm going to make a guess that rotor valve timing has to do with where they grind the intake port on the crankshaft. Am I correct? If not, could you expand on exactly what you mean by "rotor valve timing"?
Awsome info kweasel.
Could you refer me to a book or website where I could read up on this type of RC engine technical information, eg rotor valve timing, liner porting, etc.?
Thanks again.
Thanks again.
