Older engines..Which is the strongest/weakest?
CA
Guys: Which of these engines are the strongest and weakest. Put them in order for me if you will. Thanks
K & B 61....C. Lee customized
Webra 10cc Blackhead
Webra 50 GT Speed
Enya 60 III
Webra 50 GT Speed
Enya 60 III
My Feedback: (264)
MD
RE: Which is the strongest/weakest?
This would be my semi-educated guess...............
1) K & B 61....C.F. Lee customized
2) Webra 50 GT Speed
3) Tie? I don't know, but I think it would be close. The blackhead webra is loop charged I think, and I'm sure the Enya is.
Enya 60 III
Enya 60 III
CA
Thanks rcdude, for your reply. The reason I am asking is that I am trying to match engines/mufflers with kits/scratch build projects. I lot of my stuff is from the 80's. I have many options with regard to mufflers, in-cowl, pitts and standard. Will the Enya and Webra be adequate for a Jemco Hellcat or a Ugly/Sweet stick 60. I know the first two will fly a Kaos 60 but what can I do with the others. I bought the Webra from a guy with a kit (Sig Comet) for 40.00 back then but I am not sure If it will fly a pattern plane. I have Kaos, Sun-fli, Quick-fli, Bridi Aircruiser and a few Jemco kits as well as the 60 size stick kits/plans. I know it depends on the performance goal but i need some place to start. What were these engines intended to be used with back then. Any help would be appreciated.
My Feedback: (20)
ORIGINAL: tucker1865
You'll have to experiment with the mufflers as the in-cowl/Pitts style mufflers don't seem to work as well. (at least that's what I have found)
Some of the older Webra engines used a needle bearing in the top of the "forged" connecting rod. Use good quality fuel/oil and you're set for life.
I like the old stuff.
RE: Older engines..Which is the strongest/weakest?
They will all be of different power levels which is dependent upon the need. If you need a big lumber spinner for a scale cub, use the K&B or the Enya, they both have good torque and will spin a 12x6 to 13x5 quite well. If you are building a pattern style plane that you will want a bit more speed with use the Webra 60.
The Webra 50 is "40" size and weight and will give ballistic performance to any 40 size plane.
