Weird LA .40
Old 03-12-2002 | 03:38 AM
Balsa Duster's Avatar
Default Weird LA .40
my os La .40 has a metal needle valve holder like the .65
when all the other .40 la's have the plastic ones.
I know its not a big deal just found it kind of differnt.
Old 03-12-2002 | 03:56 AM
My Feedback: (8)
Default Interesting
Maybe OS is getting serious about improving the quality of their LA series engines. If they could only improve the carb with a bigger throat to allow more air/fuel mixture...
Old 03-12-2002 | 04:13 AM
That engine is 1.5 years old. (about)
so I dont think so.
That is what makes it strange.
bought it in a plane engine combo.
Yes the carbys are very small
but they are cheap great for combat beaters and trainers
Old 03-12-2002 | 11:17 PM
That's normal nowadays with the LA .40. The original plastic remote needle valve was too easy to break, and O.S. has since made the metal bracket standard on it's engines. Most likely the engine was in a crash at one time or another, and the owner put the metal one on, or depending on when O.S. implemented the metal version, it came like that.
Old 03-13-2002 | 02:39 AM
Im the original owner.
the plane combo was new from tower
Old 03-13-2002 | 02:58 AM
Oh, I thought you meant you bought it from someone in a combo. You must have got it right when O.S. started building them like that. Then again Tower could have done it.
Old 03-13-2002 | 09:20 PM
I bought mine (LA .46) last May and it has a metal needle valve holder. I would be nice if they had a metal needle valve body. I have already broke the nipple off once... over $7 to replace it!
