OS 46?? Stumped
OS 46?? Stumped
Pulled this engine out of retirement ran well then, now will not stay running
low end is fine
high end is set perfect even a little rich
get her up , half a tank later she has no power to lean, I land richen 5 to 6 clicks goes back up fine plenty of power.
tank center line with carb no bubbles in line ??????
low end is fine
OS 46?? Stumped
You might check the muffler pressure nipple and line to be sure they're clear and not restricted. Any air leaks in the tank like an uncovered 2nd vent or fill overflow will also cause what you're experiencing.
Re: OS 46?? Stumped
low end is fine
low end is fine
Well I just switched it out, I'll take it apart look it over on a rainy
day. Thanks now I know where to start
If I boil it in anti freeze will that give a clean start
before an entire breakdown????
Thanks for the Help
Thanks for the Help
