Pipe size and power curve
Another question, Macs makes a 7.5cc pipe for 40-50 size engines. They also make a 8.5cc pipe for 45-60 size engines. What would be the performance difference between these two pipes on a 50 size engine? Thanks, Mike
Community Moderators
My Feedback: (42)
I'm not sure what the performance difference would be, but your .50 is 8.5cc. I couldn't imagine running that 8.5 pipe on a 60 which is 11cc. At the same time, the 7.5 pipe is probably a little on the small size for your .50 being as how they make an 8.5 pipe.
John
John
60?
JWN,
A .60-.61 is a 10cc engine.
Most companies make pipes that are usable for a range of engines. A .60-.90, a .40-.50... An 8-11cc pipe would entertain both a .49" (8.0cc) and a .68 (11.1cc).
If that is not a legitimate range, what is?
And yes, when there is a range involved, engines in the top do tend to put the pipe at its limits.
Sincerely,
Sincerely,
My Feedback: (42)
Re: 60?
I personally would run a pipe sized specifically for a .60 instead of buying one that works on a wide range of engine sizes. Pipes are critical to setup properly. Why get into a "one size fits most" situation when there is a better alternative? If I'm installing a pipe on a model, it's because I want the most performance as possible. To me, there is no room for compromise.
John
My Feedback: (34)
Would have to agree with the previous post. Match the engine to the pipe. We are very much into pipes with marine engines. You can "pipe up" use a larger pipe in some instances but you run them longer if you do and low end needle is tough to get sometimes. We never pipe in a range to get max. power and output.
Curt
Curt
