What size fuel tank?
CA,
I have recently purchased a Vectorflight 66" wingspan Extra 300S(www.vectorflight.com). It is billed as a .60 size plane and comes with a 12oz fuel tank. The engine I have for it is a Magnum .91 XLS. I understand fuel consumption will depend on how throttle is used. The supplied 12oz tank seems a bit small for this engine regardless of how much throttle is used throughout flight. I am usually satisfied with no less than 15min. flight times. Can anyone make a recommendation on what size fuel tank I should have the supplied tank replaced with to achieve around 15 minutes? Thanks.
~Noah
~Noah
Always remember SIZE DOES MATTER, go for the biggest you can fit. I'm using an 12oz tank on an asp.91 i don't fly full throttle all the time I'm always playing with it. I kinder fly 3D/Fun. After about 10mins i come in with approx half a tank. But like i say to be safe always go BIG. Hope this helps.
