ABCvs ABN
Tapered bore
RCPaul,
Chromium plating is much more durable than nickel plating. It is also better binding and much less likely to peel.
The OS copper flash process make a better ABN bond, but it is still no match for true ABC.
Break-in procedure for all tapered bore engines, including plasma and composites is identical.
Chromium plating had a single drawback and it is an environmental issue. Chromium compounds from manufacturing, need more thorough treatment, so as to prevent pollution. So some manufacturers prefer the nickel process.
Sincerely,
Sincerely,
