1.60fx prop
ON, CANADA
1.60fx prop
What prop for the1.60fx? I bought a APC 18 4W will this work in a 25% H9 540 edge? I would give up speed for thrust . Thanks for the help.
My Feedback: (16)
1.60fx prop
I haven't tried or heard anyone trying the 18x4W. I am currently using an 18x6W. The consensus seems to be either that prop or the Mejzlik 18x6 or 8 are good choices.
Mike
Mike
My Feedback: (21)
1.60fx prop
With the 18x4, the plane will barely fly. I'm afraid you won't have enough pitch speed. The engine will also be doing over 10,000 RPM, which is an awful lot for one this size.
An 18x6W will haul 15lbs straight up as far as you want to go. What more could you want?
My Feedback: (31)
NC
1.60fx prop
i have tried the following:
18 x 6W APC slow spool up exellent verticle
18 x 6 Zinger Pro quick spool up exellent verticle (loud)
18 x 6 Mejzlik quick spool up 9600 RPM may not be enough prop
18 x 8 Moki Wooden Prop very fast prop fast verticle
3d i like the zinger pro,
imac i like the mejzlik, apc the apc braking is not great but good.
i like the moki for sheer speed at less than 1/2 throttle.
