Saito 82 Stalling issue
VA
I have a Saito 82 that I've had for several years. The last few flights my engine stalls in mid-flight at or around 6 minutes into a 13 minute flight. I've tried new glow plug...new fuel...reset and reset engine settings. I get perfect performance at each full tank but again...at 6 minutes engine sputters...and stalls. Tired and freaked about the number of deadsticks I've had to deal with.
Please help!!!
Please help!!!
My Feedback: (16)
The 82a has been around since 2003 or somewhere along there
It has the cylinder bore of a 100 and a stroke less than that of the 72
Exterior size is much the same as the Saito 72. Has a common mounting bolt pattern with the 72, 45, 50 56, & 62. But the 72 and 82 are a little wider across the crankcase
The 82 has power very close to what the 91 does. It will pretty much swing the same props
There's a new 82 that will be available in a few months with a redesigned crankcase.
