Which 2 strokes have a ringed piston ?
RE: Which 2 strokes have a ringed piston ?
K&B .40, #8011
Testors/Mccoy 19
OS46SF ringed
Irvine 150
Fox 40 ringed
Just off the top of my head, that are currently in my collection
Testors/Mccoy 19
OS46SF ringed
Irvine 150
Fox 40 ringed
ORIGINAL: blw
OS 120AX
OS 95AX
OS 160AX
GMS engines above 46
K&B .61
ST .61
for some of them
OS 120AX
OS 95AX
OS 160AX
K&B .61
ST .61
for some of them
OK,
i think i was in a hurry when i started the thread,earlier.
First of all,
we refer to "ringed piston" when the connecting rod that connects the rotating crankshaft with the piston uses #2 rings one on the piston/connecting rod and one on the crankshaft/connecting rod.
Right?
Also,
an engine with ringed piston can use only one ring on the connection connecting rod/crankshaft and use a simple pin to connect the piston to the connecting rod ?
If so,
does my 91FX use a ringed piston assembly ?
http://downloads.hobbico.com/evpl/osm/ev19020aa.pdf
TX
A piston ring, or ringed engine refers to the piston having a ring towards the top and is to assist in sealing the combustion chamber.
dan
dan
I am a little confused here[:-] Anyways ringed engines are just that, ringed engines, the rest are ABN, ABC.
Why list every single one here? it will be a verrrry long list
ORIGINAL: jeffie8696
I think he is talking about a bushed rod.
My Feedback: (102)
Gorsh, if I just list the ringed ones I have, I'll be all day, here's a partial list.
(1) Webra P5 .91 ringed
(3) Webra .91s two ringed, one ABN
(1) Webra Speed .61f ringed
(1) Webra SilverLine .61 ringed
(1) Webra .50 with Dykes ring
(1) Silverline .40 ringed
(3) Fox .74s==two ringed, one ABC
(3) Fox .60s =all ringed.
(1) Fox .50 ringed
(2) SuperTigre 4500s ringed
(1) SuperTigre 3000 ringed
(1) Seuvia 1.50 ringed/roller bearing crank.
(1) Fox .50 ringed
G'day Dave
And I know they are not two strokes but your and my Lasers have two rings each. That's because they are 4 strokes and not 2 strokes and 4 = 2 x 2. I put this in because I can't really see where this thread is going.
On a slightly more sensible note, there was a time when many manufactures made both ABx and ringed versions of their engines. Super Tigre was one and OS.
My Feedback: (102)
Hey Mikester, Fox made a few engines that came in both ringed and non ringed. I don't have any non ringed fourstrokes, just Saitos, Enyas and the LASER .70. I sold my OS .52 a few weeks ago.
Since this is kind of about engine piston to cylinder seal, my PAWs are steel in steel and my Fox .25 is Meehanite in steel, the PAWs might be too. None have rings. On the PAWs and the Fox 25, you could hold them against compression all day and they will not leak down.
NY
Engines that I have, that are ringed.........LOL!
OS 61rf, os61sf, os28f-h, os32f-h, os61sf-h, os61rfn-h.
OS 40fsr,45fsr,61fsr
the old os58R/C has 2 rings
ST S75K is ringed
K&B 40 is ringed
Irvine 61 side exhaust, Irvine 61R rear exhaust.
Send an Email to Frank Bowman, He'll send You a list of engines He makes rings for.
Over 200 by My count.
[email protected]
Jeff
ST S75K is ringed
K&B 40 is ringed
[email protected]
Jeff
ORIGINAL: Kostas1
The engines I listed do have single piston rings.
Yes, your engine is a ringed engine.
My Feedback: (79)
ORIGINAL: carrellh
You may be right. In these pictures the rod with a bushing on one end is an OS and the Davis Diesel rod has bushings on both ends.
Look, OS is even cheapening there Rods now too.
Here's a couple more for the list, the OS Max 40-H & the Irvine 40 Sport (UK made version) [8D]
OS Max 40-H = have four of the OS engines - with two having a dykes piston ring & the other two having a "normal" piston ring
Irvine Sport 40 = have a few of these as well - they are all dykes ring
ORIGINAL: MOTORMAN37
ORIGINAL: carrellh
OK i made a big mistake !
When i was referring to the "ring" i wanted to say *ball-bearing* !!!!![:-][:-][:-][:-]
I AM REALLY SORRY FOR THIS.
So,
my question is.
Is there any engine that uses a ball bearing for friction free connection between the crankshaft & connecting rod (1st BB) and between the connecting rod & piston/piston pin (2nd BB)
I really apologise for my mistake!
Also,
because someone mentioned that the DD connecting rod has two bushings ,
instead of one.Is this bushing a friction reducing material? ?
Hi!
You mean needle bearing?
Yes! The MVVS .40 F3D engine had a needle bearing on the lower part of the connecting rod at one time. MVVS also has needle bearings on their 26cc glow and gas engines.
ORIGINAL: Kostas1
When i was referring to the ''ring'' i wanted to say *ball-bearing* !!!!![:-][:-][:-][:-]
So,
my question is.
Also,
Here I thought all along Kostas was a spokesman for OS. Look, OS is even cheapening there Rods now too.
ORIGINAL: carrellh
So,
my question is.
Also,
Sounds like you are wanting to convert a glow engine to gas. As a general rule, no needle bearings. You either have to run more oil in your fuel from a designed gas engines or make a rod to fit your spec.
My Feedback: (79)
ORIGINAL: Kostas1
So,
my question is.
Also,
ORIGINAL: carrellh
So,
my question is.
Also,
Now you are saying ball bearings. Do you mean Needle bearings? Most of the good engines have double bushed rods. Engines that don't are useing a High Silicon content Aluminum for the Rod material, which with adequate luubrication works pretty well, but in my opinion is no match for a Rod with two Bronze bushings which are superior to a ALL aluminum un bushed rod.
