Acidic Nitro
G'day
Remember, he was measuring the pH of the nitro he bought, not of the fuel he made. I agree, 1 is very acidic. Did you read the original article? Link above.
Cheers
Cheers
Yeah I did read the original post on the Aussie forum, but I still think that the pH 1 is incredible for nitromethane production. I would tend to lean toward contamination at a the local packing company.
I don't think it would be at the chemicals manufacturing plant because such a high acidity will have a knock on effect on the overall plant operations. Pure nitromethane is however acidic, not neutral.
This however is an important post because nearly all fuel that we buy uses imported Nitromethane thats blended locally by a chemicals company that will also blend other chemicals. The opportunity for cross contamination is high if the facility does run-down blending and utilises the same piping for the other chemicals products. You think its unlikely that mistakes can be made but I have seen it at large and small operations.
Just a point to note: Any fuel is either slightly acidic or slightly basic. It will never be neutral. Hence most fuel companies whether gasoline, diesel or Jet (Kero) or oxygenate type fuel producers, add stabilisers to the fuel to limit the corrosion properties of the fuel as well the fuels own affinity for oxidation.
My Feedback: (14)
ORIGINAL: AMB
earlwb The US modeler is hooked on nitro to get that last bit of performance out of that higher compression glow engine and yes
easier to tune, In other parts of the world FAI no nitro is widely used and of course diesel ( I FLY MAINLY DIESEL). On my 4 stroke
glows OS, Saito, ASP. I run a bit of diesel thru it after glow, of course the glow plug on, the Kero and castor do a great job of getting rid of any glow leftovers, this my after run treatment. Ihave never had a corrosion issue or bearing failure
on my OS instruction sheets even states if storing the engine give it a good rinse with Kerosene. martin
The majority of young modelers are being led by the model publications and the marketing folks' advertising into thinking that only the most powerful engines and fuel are worth consideration for their models. They actually behave as though they are racing against one another. P-shaw!
There was a time when low nitro was cool (environmental awareness) and engines burning little to no nitromethane in competition were considered "cool". Remember OPS, Picco and Rossi engines? Besides being cheaper to operate, the latter type of engines required more technical finesse to design and operate. I miss those days.
Ed Cregger
Ok group one more thing I saw on my instruction sheet with my MVVS 15Diesel, they state leave the piston at the bottom of stroke when storing this prevents any exhaust residue from being trapped (and moisture which can even come from the air which will condense some water out of the air when the engine cools) very good advice glow or diesel,no moisture trapped and alcohol even more to adsorb moisture this allows it to evaporate and leave the engine dry of course there is some oil still coating the engine but good insurance for any engine glow or diesel martin
the moral of the story is to run whatever anti corrosion you are using THROUGH the engine. Immersing the engine does nothing for it. So whether you use after run oil, diesel or kerosene distillates or heavier stuff like any polar molecule containing lube oil (motor oil included), run it through the engine and drain excess. The polar nature of the additives and the doublebonded molecules with paraffinic tails will adhere to the surface and protect it from corrosion. The trick is running through and drain.Anyone submerging engines is looking for trouble because nothing has drained especially the nasty stuff
#31
My Feedback: (14)
Blah - Blah -Blah!
original quote attributed to: Eustice Baggs (Courage The Cowardly Dog).
My point being that after reading what everyone has espoused, including myself, I still do not see a clear and proven method of engine storage treatment. No one agrees with anyone else!
Ed Cregger
Ed Cregger
#32
I have heard arguments before that we have "better" synthetic oils here, and might be true, but it does sound a little odd that there would be a difference now days when everything is being shipped all over the world and back. The quality of Nitro is an interesting idea, the price is much higher here (I would have to pay about $40 for one litre of nitro) and that might mean that we are used to a higher quality too. I will have to dig up some litmus paper...
#34
Sounds like astrongacid with a Ph of 1. Sulfuric acid and weaker soloutions of HCL perhaps. I doubt nitro could degrade to that extent. Probably a bad batch,or the wrong chemical was poured into the jar.
#36
actually its Acidly neutral, the pH is just below 7 remember...
chemically speaking anything below 7 is acid anything over is basic. Only 7 is neutral..
Ed, I agree blah blah blah. there is no right way. There is only science. The science says that in order to prevent corrosion you must displace the stuff causing the corrosion with something neutral or slightly basic.
Many neat synthetic oils tend to be slightly acidic hence they require the addition of basic additives to neutralise acids in the oil on the metal parts. This is why almost no synthetic motor oil is actually fully synthetic but a blend of mineral and synthetic components. Also hence why in RC engines, a blend of synthetics and castor is ideal.
you could even simply run your rc fuel through the engine with the glow plug removed and your finger over the plug hole. The pumping action removes the burnt stuff and replaces it with unburned fuel and oil thats far more friendly to the engine.
#37
ORIGINAL: TimBle
What is the PH of castor oil?
If you put your finger over the plug hole, why even take the plug out? Is it to put in fresh fuel through the plug hole? If you are doing that, why not just load it up with ATF or air tool oil? Why not just run FAI fuel, with no nitro since nitro in the big offender, Right? And, what is the PH of FAI fuel? What 2 stroke oil do you recommend for gas engines? (I had to add that last just to stir up the hornets nest some more). Thanks.
Regards,
Richard
#38
ORIGINAL: spaceworm
Regards,
Richard
Regards,
Richard
So then we wouldn't have any PH info for FAI fuel either as it is methanol and castor oil.
Yes FAI types of fuel is the way to go, no nitromethane in it. But here in the USA most modellers are hooked on using some nitromethane in their glow fuels. Usually many engines in the USA market are designed to use nitromethane in the glow fuel too. These engines typically do not run all that well off of no-nitro glow fuels. You would have to modify them to work better.
As for gasoline engines, use whatever 2 stroke oil you like a lot more to choose from. Since gasoline engines don't normally run nitromethane, you won't have any problems.
But years ago the special synthetic 2 cycle oils were known to be hydroscopic and tend to absorb moisture. A lot of guys found out about that the hard way, after parking their 2 cycle motorcycles for the winter. Then when they went to use them in the springtime, the bearings were all rusted out and bad. So it goes to show that synthetic oils do not really protect a engine from corrosion on the inside. So that led to the oil companies using blends with synthetic and mineral oils as one solution.
Now as for those gasoline engines that have been converted to run nitromethane and methanol, you have the same corrosion issues from nitromethane. But usually these engines are used in racing, so they get taken care of really well. If it is a 4 cycle gasoline engine, you need fire protection systems in the sump to prevent sump fires or put them out. That can get exciting if it happens to you and you are in the drag car sitting behind the engine when it occurs.
#39
#40
Castor oil has an acid value Pk of 1 to 2 which is very low. This means it only needs one or two milligrams of potasium hydroxide to neutralize it. Hardly worth worrying about.
#41
Why can't they put a buffer in the fuel so that no matter what the burn products are they would be neutralized?
The one idea here that sounds sure fire is the diesel fuel. Does it ignite and run well enough in a glow engine to clean it out? I'm wondering what happens when you put something with 25% ether inside a four stroke and fire it up. Maybe it's fine. If so, it sounds like a great technique. If not, then keep a bit of no nitro all castor fuel on hand for a few second run at the end of the day sounds like the next best thing.
Jim
Jim
#42
You know, many glow engines, especially those intended for little to no nitromethane in their glow fuel, will run off of model diesel fuel. Some engines run pretty good off of model diesel fuel other engines not so good. You would need to temporarily hook up neoprine or gasoline proof fuel lines to the engine before you tried it as the kerosene and or ether will eat up the silicone fuel lines.
Now you could just as easily simply run some FAI fuel through the engine (methanol and castor oil no nitromethane) and you would get the same effect. You would not even need ARO after you are done. So that might be a better solution. hard to say until some people try it for real.
#43
NY
I use some stuff called "ZIPP" in the heating trade and tried it in my engines to clean them out works like a charm ,clean and 100% dry, follow it up with some aro and no rust "ZIPP" can be had at your local heating supply house but be mindful it is a chlorinated solvent so keep it away from plastics.
for baked on residue use "grime solve" and rinse with "Zipp" the grime solve will turn plastic/ paint to mush but will cause baked on fuel to literally disolve on contact and leave behind nice clean bright shiny metal, don't tell anybody I told ya it's a trade secret, it's extremely good stuff ya just gotta be careful what ya spray it on both products will haze plastic on contact and turn it into a gooey mess if you leave it there long enough
#44
ORIGINAL: buzzard bait
Jim
Jim
To avoid gumming up, due to the full castor diesel fuel, a bit of after run oil is also useful.
#45
CAn we get some readings from different people here on their factory mixed fuels.
Iwill start. If I am reading the test strip right it came in at a 3.
The fuel was Morgans Omega 10% nitro with 4 oz added castor.
#46
ORIGINAL: NM2K
Consider that nitromethane was originally mass produced for sale as a solvent to be used to remove newspaper ink from presses, etc. That was its largest use for many, many years.
What are they cleaning today and then reselling the nitro as a fuel additive? Methanol suffers the same fate in some instances.
Have you ever wondered why some fuels were so much less expensive than others? Could it be...?
Ed Cregger
Ed Cregger
#47
ORIGINAL: spaceworm
Regards,
Richard
ORIGINAL: TimBle
Regards,
Richard
I don; know why people do the strange things they. If I did I would have a cure for Crazy but I don;t so Crazy is still out there.
A few drops (like 10 maybe) down the carb, urn the engine over many times and then a few more drops of oil and turn it gain is all thats needed. Some fuel manufactures say no After Run Ol needed because they have Castor oil in. When running Omega I don't bother with after run oil. In fact I seldom bother with after run oil. If Ido, it's just the remains of the last top oil I used in my Golf, 10w 30 synthetic.
What you don;t want is to use methanol fuel as an afterrun oil. It has no lubricity (think engine seize), and contains oxygen (which promotes rust). FAIfuel has oil in it so i guess thats fine biut pure methanol , no no.
#48
Generally I've had no problems either, but recently some guys in the club have had bearing failures on pretty new engines, including a Saito 100 and an OS 81a...expensive engines! There have been posts about others having failures too, so it makes me wonder if a better procedure might be needed. I like the idea of a short run with no nitro, all castor fuel because it would clean everything else out.
As for diesel fuel, I think it's the amyl nitrite (?...the ignition improver), isn't it? I think the kerosene, castor and ether are all fine.
Jim
Jim
#49
#50
I don't bother to run the engine, Simply apply starter motor and flood it with fuel. then drain the fuel. All the nasty's should be out and all thats leftis the methanl with oil.
The methanol wil evaporate over a few hours leaving just the oil.
However Methanol contains oxygen so it can also promote corrosion if left behind for too long. At the end of the day, there is no fuel proof method to prevent corrosion entirely. On Planet Earth, water is everywhere
