Golden Age, Vintage & Antique RC Want to discuss some of those from the golden age, vintage rc planes or even an old classic antique vintage rc planes, radios, engines, etc? This is the place for you. Enjoy!
Fleet Brotherhood
Old 06-29-2013, 03:33 PM
  #601
retransit
My Feedback: (18)
retransit's Avatar
Default RE: Fleet Brotherhood
Nice paint, Dave. Good work!
I'm confused about the need for a servo reverser. Details?
Bob
Old 06-29-2013, 04:53 PM
  #602
dabrown
dabrown's Avatar
One servo for each elevator half. Servos mounted so that the arms rotate in the same direction, or should I say opposite direction, since the servos rotate counter clockwise for up and clockwise for down. Or is it the other way around? Anyway, it's a symmetrical set up. I could have slid one of the servos over so they both rotated the same direction, or is that opposite direction, however I'm using a long rudder servo arm for a pull-pull setup, so there wasn't room. I'm sure that makes absolutely no sense, but I can't come up with a way to describe it.
I spent alot of time trying to figure out how to program my futaba radio to slave a channel to the elevator servo channel and it would work except the trim only worked for the elevator servo channel and the slave wouldn't trim with it. If somebody knows how to do this, please let me know.
OK, a trip out to the garage to take pics...and to also show a pic showing the rivet/screw detail on the stab done with, I believe your method using yellow glue.
Dave
ID:	1896229   Click image for larger version
Old 06-30-2013, 07:37 AM
  #603
retransit
My Feedback: (18)
retransit's Avatar
Your description made sense to me. I don't know if that's good or not.
The reason I asked in the first place is that I used a wire joiner between the elevator halves, similar to the full sized aircraft, negating the need for two servos.
Bob
Old 07-12-2013, 04:51 AM
  #604
TorkRollN
My Feedback: (22)
OK,
I need a 1/3 scale Concept Fleet Bipe !
Where can I get a kit or plans ?
Barry
Old 07-12-2013, 06:01 AM
  #605
Kinner
Concept is out of bizz but plans and a kit 91/3rd scale) can be purchased at Precision Cut Kits. It builds a bit diffeent than Concept model but the lazer cut fits well. Plans alone are available through Ziroli's web site. Look for Ron Wiess 1/3scale Fleet.
Ray W.
ID:	1899805   Click image for larger version
ID:	1899806   Click image for larger version
Old 07-14-2013, 03:47 PM
  #606
dabrown
dabrown's Avatar
Here's my same post as on the Concept Fleet forum:
First flight yesterday...
Way out of trim and I know it was because of the wing rigging. Also, power was marginal with my Quadra running so-so.
So I have things to work on. Then on to finish cockpit seats, pilot, windscreens, etc.
Dave
ID:	1900320   Click image for larger version
ID:	1900321   Click image for larger version
Old 07-15-2013, 07:42 AM
  #607
dgliderguy
dgliderguy's Avatar
Dave,
I LOVE your colors. Man, what a smart looking bird.
Old 07-15-2013, 07:58 AM
  #608
Kinner
I love your flying field.
Ray W
Old 08-07-2013, 07:04 AM
  #609
dabrown
dabrown's Avatar
Last week I went back and tried to re-rig the wings. I ended up having to trim about 3/32" off the inboard half of the rear spar/wing joiners on the right wings to get the wing to align with the center section and the left wing. So basically the right wing spars don't line up with the center section and before I modified the joiners, the trailing edge of the right wing was about 1/8" lower than the center section trailing edge. Not sure how that happened...as soon as I figure out who to blame, I'll let you know.
Went out Saturday and flew the Fleet again and it was much better -- close to no trim needed.
Only the one flight as I had trouble with the fuel line arrangement with my Quadra which has the fuel feed nipple on the front so if the fuel line isn't just right the cowl tends to pinch it. And the carb came loose. So after removing the cowling about 5 times, I called it a day. When I got home I also discovered the landing gear wire brace came loose from where it's soldered to the bottom of the main gear leg.
So I have a bit of work to do.
Nothing new with this pic, just testing to see if I can post a pic.
Dave
Old 08-07-2013, 08:04 AM
  #610
Kinner
Alot of tension on that joint where the braces meet up at the wheel hub. I notched my spreader wire before I wrapped it in copper and hadn't an issue with it yet. Even made it through the crash.
The new format suprised me a little. Seems to look nice and the print is a bit bigger which is always a good thing for old eyes.
Ray W.
Old 08-07-2013, 12:45 PM
  #611
dabrown
dabrown's Avatar
Notching the wire sounds like a good idea. I may be able to notch it and shove it back into the copper wire wrapping and re-solder.
I notice I have to log in every time...looking for a way to stay logged in like it worked before.
Dave
Old 08-07-2013, 01:22 PM
  #612
Kinner
Good cleaning at that joint is in order too. Might have been a cold solder or sumpin like that. That wire come with some maching oil from the forming process and maybe it contaminated a tool or ....
I notch my wire with a dremel and disc cutter.
Ray W.
Old 08-12-2013, 06:41 AM
  #613
retransit
My Feedback: (18)
retransit's Avatar
Dave, did you get your gear fixed?
I silver soldered mine with Sta-Silv, but after the process I had to heat treat it so it wouldn't break from being too hard or bend from being too soft.
Old 08-12-2013, 01:54 PM
  #614
dabrown
dabrown's Avatar
Haven't worked on it yet. I'll try regular solder again with some notches ground in the wire. See how that works.
Dave
Old 09-03-2013, 04:37 AM
  #615
circuitboard35
Is it too late to join the brotherhood? I have a 1/4 scale NIB waiting for time to build it. I was a member of the Madison WI club,(MARCS) at the time Romey flew the prototype Fleet here. I had wanted one wver since. I finallay called him a few years ago, and he was assembling kits as orders came in.
Dave
Old 09-03-2013, 05:39 AM
  #616
retransit
My Feedback: (18)
retransit's Avatar
Dave, you're #27. What do you plan to power it with?
Old 09-03-2013, 06:38 AM
  #617
Kinner
good to read you Bob. Still hot down there? Nice Summer here until Sept. I went to my flying field and it was just too hot to maiden my NE-1. No one else there either.
Welcome in Dave.
Old 09-03-2013, 07:34 AM
  #618
circuitboard35
I don't have any real plans yet for power, let alone even starting on it. Have had the box for 3 years and never even opened it. Been kind of on and off with rc for almost 40 years, more off than on and haven't really kept up too close on what's out there.
Old 09-03-2013, 10:59 AM
  #619
retransit
My Feedback: (18)
retransit's Avatar
Dave. hopefully your involvement with this thread will get you going. If you need any help or pointers, just come here and pose your questions. The Brotherhood will be glad to help.
Old 09-03-2013, 11:09 AM
  #620
retransit
My Feedback: (18)
retransit's Avatar
Welcome in Dave.
Ray, how's your 1/3 Fleet getting along? Still hot down here. Maybe it's just me and the heat, but Georgia (where my younger son lives) is looking better and better.
Old 09-03-2013, 11:30 AM
  #621
Kinner
The 1/3 scale is almost done. I'll finish up the wing struts and joinery. Young AF lad made me an engine break in stand for the OS 300 before he deployed for a few months. I'll have to make some pix and put them up.
Sister in Atlanta says it has rained nearly every day this summer. 14 inches above normal. We're 12 inches up after a 9 year droubt.
We have mosquitos that demand the remaining K&B 100 fuel I have stored away in a gallon can. I love the smell of that brand when used.
Ray W.
Old 09-03-2013, 02:05 PM
  #622
retransit
My Feedback: (18)
retransit's Avatar
My son lives south of Atlanta in Newnan and he said the same thing about the rain. They were begging for rain a couple of years ago.
By the way, is that 3.00 their opposed twin?
Old 09-03-2013, 03:58 PM
  #623
Kinner
Yes , opposed twin. I've got a McDaniel/SonicTronics onboard glow and a 2000Mah. Went 6 volt dual batteries with a BattShare goodie. Should handle the biggie servos.
Ray W.
Old 09-05-2013, 11:30 AM
  #624
circuitboard35
Thanks Bob. I was lucky enough to see the maiden flight of the original concept fleet here in Madison. I have wanted one ever since. That was quite the monster back then. Way back when when Romey was kitting the 1/4 and 1/6 scale fleets along with the scout trainer among other things, he would open up his shop once a year for the cheap among us to pick thru the scraps of would that he wouldn't use. I think the kit is going to be my retirement project if I make it that far
Old 09-08-2013, 08:59 AM
  #625
Kinner
Bob,
Have you gotten your motor back for BJ's? I got my Cub on a maiden and between the heavier Cub than the Sig, and... an old 25 year old motor that hasn't been used in 20 years, it was noticeably weaker and belched a boat load of rust and old goo.
I may keep flying with it until Fall and then I may install an OS 110 I just got. It suposed to bolt up straight away but we'll see about the carb and muffle placement. I hope not to have to modify anything other than the carb linkage.
I may go with SonicTronic ignition as the .91 still idles so realistically nice.
Ray W.
