Go Back  RCU Forums > RC Airplanes > Golden Age, Vintage & Antique RC
Reload this Page >
Gilmore Red Lion Build
Golden Age, Vintage & Antique RC Want to discuss some of those from the golden age, vintage rc planes or even an old classic antique vintage rc planes, radios, engines, etc? This is the place for you. Enjoy!
Old 10-08-2015, 10:34 AM
  #551
FlyerInOKC
FlyerInOKC's Avatar
The prototype (which I also plan to build) had an inverted straight line engine and the cowling looked very similar to the STA cowling I hope it will be easier to replicate.
Old 10-08-2015, 12:19 PM
  #552
Melchizedek
Melchizedek's Avatar
Another layer of glass was formed off the plug floor. This layer will become the flange of the blisters.
Once that was cured the footprint of each blister was laid out square to the radius then cut out and sanded to size.
My plan was to use the glass blisters but that did not pan out. By the time they were paired down to fit the flanges the bubble was to shallow. So I will have to make 4 blisters.
Each blister will be made up apart from the plug floor. When shaped to satisfaction they get glued to the floor.
Kevin
Name:	m_Remake of cowl Blisters 93 001.jpg
ID:	2124416   Click image for larger version
Name:	m_Remake of cowl Blisters 93 002.jpg
ID:	2124417   Click image for larger version
Name:	m_Remake of cowl Blisters 93 003.jpg
ID:	2124418   Click image for larger version
Name:	m_Remake of cowl Blisters 93 004.jpg
ID:	2124419   Click image for larger version
Name:	m_Remake of cowl Blisters 93 005.jpg
ID:	2124420   Click image for larger version
Name:	m_Remake of cowl Blisters 93 006.jpg
ID:	2124421   Click image for larger version
Name:	m_Remake of cowl Blisters 93 007.jpg
Old 10-09-2015, 05:05 AM
  #553
FlyerInOKC
FlyerInOKC's Avatar
My plan was to make the cowling out of balsa then carve the blisters then use that as a plug.
Old 10-09-2015, 11:06 AM
  #554
Melchizedek
Sounds like a plan Mike.
Do you have any of the plane built yet ?
With the flanges made attention was paid to the blisters bumps. They shaped from balsa on the band saw.
Once the plan view was cut. The off fall was save so the elevation could be cut. But first sand paper was stuck to the plug floor and the contour was sanded in. Part of the blister dips over the bull nose. A line was drawn on the plug floor so that the contour was sanded at the correct spot on the blister blank.
Then the side view was laid out and cut.
Then I set about sanding them, the first one took the longest of course with each one moving faster.
At the moment they look a little tall but that should go away once the fillet is in place.
Next the blisters got glassed. I did this now so when the fillet is sanded in, the edge of the blister doesn't get grooved.
Kevin
Name:	m_Remake of cowl blisters 94 001.jpg
ID:	2124575   Click image for larger version
Name:	m_Remake of cowl blisters 94 002.jpg
ID:	2124576   Click image for larger version
Name:	m_Remake of cowl blisters 94 003.jpg
ID:	2124577   Click image for larger version
Name:	m_Remake of cowl blisters 94 004.jpg
ID:	2124578   Click image for larger version
Name:	m_Remake of cowl blisters 94 005.jpg
ID:	2124579   Click image for larger version
Name:	m_Remake of cowl blisters 94 006.jpg
ID:	2124580   Click image for larger version
Name:	m_Remake of cowl blisters 94 009.jpg
ID:	2124581   Click image for larger version
Name:	m_Remake of cowl blisters 94 007.jpg
Name:	m_Remake of cowl blisters 94 010.jpg
ID:	2124584   Click image for larger version
Name:	m_Remake of cowl blisters 94 011.jpg
ID:	2124585   Click image for larger version
Name:	m_Remake of cowl blisters 94 012.jpg
ID:	2124586   Click image for larger version
Name:	m_Remake of cowl blisters 94 013.jpg
ID:	2124587   Click image for larger version
Name:	m_Remake of cowl blisters 94 014.jpg
Old 10-09-2015, 12:10 PM
  #555
FlyerInOKC
FlyerInOKC's Avatar
I have the main and rear spars built (about 20 pieces each and the ribs dry fitted. I also have the building crutch built. Right now I'm trying to finish a couple of old projects before I start up on the the Ryans again. That probably won't happen until spring. I haven't decided if I want to build then side by side or one after the other. Then I have a quarter scale Globe Swift project and an partial built TF .60 Corsair I got in a trade that needs finishing. And an unstarted TF 1/7 P-51D and TF Sea Fury kits. We won't talk about the other stuff I have in the queue its depressing. I really need to hit the Lotto so I can retire early!
Mike
Old 10-09-2015, 01:52 PM
  #556
acerc
acerc's Avatar
Fantastic work Kevin! You are a true inspiration to us all, keep it up.
Old 10-09-2015, 02:50 PM
  #557
stevegauth30
stevegauth30's Avatar
couldnt have said it better.
Old 10-09-2015, 06:53 PM
  #558
Melchizedek
Thank You Robert and Steve.
Old 10-10-2015, 08:26 AM
  #559
Melchizedek
Mike, when you get around to your plug, you are in for a boat load of sanding. Ask me how I know ?
Plug ready primer.
Kevin
Name:	m_Blister plug ready fo primer 96 001.jpg
ID:	2124689   Click image for larger version
Name:	m_Blister plug ready fo primer 96 002.jpg
ID:	2124690   Click image for larger version
Name:	m_Blister plug ready fo primer 96 003.jpg
Old 10-10-2015, 01:13 PM
  #560
Melchizedek
One run, one bug, and ready to sand and polish.
You ran primer ? Why yes I did !
Turns out I only had enough MEKP to catalyze one cup of primer. So needed to get this covered first go.
I sanded though the fiberglass on a small spot on the nose of the far right blister, This raw wood spot showed through as a divot. While trying to fill that divot I acceded the sag rate of the primer. Going to try and sand the flange perimeter and bring back the flange depth without going through. If this don't clean up satisfactorily it will become a 3 bay plug. The bug spot will clean right out.
Other than the sag around the end blister I am very happy with the result. Should be able to polish this puppy up and make a mold soon.
The sag
The bug
Over all
The placement of the blisters on the plug floor is evenly spaced to give as much real estate for layup purposes, front to back is how they will be on the cowl.
I think I got the scale pretty close. Maybe not perfect but better than Gov't work .
YeeeHaaa Go Cards.
Kevin
Name:	m_primed blister plug 97 001.jpg
ID:	2124757   Click image for larger version
Name:	m_primed blister plug 97 002.jpg
ID:	2124758   Click image for larger version
Name:	m_primed blister plug 97 003.jpg
ID:	2124759   Click image for larger version
Name:	m_primed blister plug 97 004.jpg
ID:	2124760   Click image for larger version
Name:	m_primed blister plug 97 005.jpg
ID:	2124761   Click image for larger version
Name:	m_primed blister plug 97 006.jpg
ID:	2124762   Click image for larger version
Old 10-11-2015, 11:58 AM
  #561
Melchizedek
Feel like I been sanding for 2 days, two 1/2 days anyway.
Sanded up the plug this morning. Was able to unearth the end blister from the globe of primer without burning thru. Yea. Sanded the primer droop out with 320. Then sanded the entire plug with 400. Then 500 sanding sponge, then 1000 sanding sponge. After that it was rubbed out with some semi polishing compound. This left a semi matt very smooth finish. I didn't polish this plug shiny though. Experience has taught me that the PVA mold release gets shiny if laid down well.
Then I back filled the lip edge with model clay so as to keep a clean sharp ridge at this point of the mold. On the first blister mold this edge was just a little bit rough.
So with the sanding done, Wax on Wax off, Wax on Wax off, Danielson. Then PVA.
Exhibit A on the shiny.
Once that was dry. Next came the first layer of jell coat.
Gonna get this bad boy molded up today, YeeHaaaaw
Kevin
Name:	m_Blisters ready to mold 98 001.jpg
ID:	2124888   Click image for larger version
Name:	m_Blisters ready to mold 98 002.jpg
ID:	2124889   Click image for larger version
Name:	m_Blisters ready to mold 98 003.jpg
ID:	2124890   Click image for larger version
Name:	m_Blisters ready to mold 98 004.jpg
Old 10-11-2015, 12:47 PM
  #562
acerc
acerc's Avatar
To everyone on my threads that thought I was anal, Hah! I am not alone anyways.
Old 10-11-2015, 04:03 PM
  #563
Melchizedek
Say, do you think if we started the " Anal Brotherhood" anybody would want to join ?
Could even make up shirts. Maybe two cheeks with wings on the front.
All molded up, hope all is well under there.
Kevin
Name:	Blisters ready to mold 98 005.JPG
ID:	2124947   Click image for larger version
Name:	Blisters ready to mold 98 006.JPG
Old 10-11-2015, 05:01 PM
  #564
acerc
acerc's Avatar
We're probably too anal for that! LOL...
Old 10-12-2015, 02:15 AM
  #565
Melchizedek
This should cure for a week. Won't be much to post for awhile. It will take 4 or 5 days to lay up all 18 once I get started. 4 at a time will be much better than 1 at a time. Kevin
Name:	Blisters ready to mold 99 002.JPG
ID:	2125008   Click image for larger version
Name:	Blisters ready to mold 99 003.JPG
Old 10-14-2015, 04:11 PM
  #566
Melchizedek
Some material I was waiting for came a few days earlier than expected, so I decided to do a layup.
First, this mold has turned out the best of the seven in quality. Very pleased with this one.
Second, thank God it is a 4 bay'r. By the time I got to layup 9 on the first version, it was feeling like it was never going to end. I'm giddy about 4 at a time.
Kevin
Name:	First quade blister layup 100 001.JPG
Old 10-15-2015, 08:33 AM
  #567
FlyerInOKC
FlyerInOKC's Avatar
That is the nice part isn't it?!
Old 10-15-2015, 06:25 PM
  #568
Melchizedek
Yes, when things go swimmingly.
When I laid up the version 1 blisters. I was constantly fighting bubbles at the flange rim. The rim is a 90 deg corner, even though it is only about 3/32 thick the glass does not want to lay into it. I overcame this pretty well with a jell coat that was heavy in the corner of the rim. I say pretty well cause I still had some bubbles.
Well with laying up 4 at a time the likelihood of bubbles goes up. Bubbles create voids.
Here is the first layup from yesterday. You can see the damage a bubble creates in pic 2 and 3.
With a little fill these are very serviceable. However, in search of the void free layup a different method was tried.
I saw hornitpilot ( Bob, Welcome back to da shop) use this method with a glass wing layup.
First some parchment paper or equivalent is rolled into a cone like a cake decorator. Then some resin and micro balloons was mixed into a thick mixture and put into the cone. Then the small crevice was filled using the applicator. Then the glass was layed over that.
I got just a little sloppy with the resin/balloon mix. Next time I will use more care.
Kevin
Name:	m_2nd 4 bay layup different way 101 001.jpg
ID:	2125550   Click image for larger version
Name:	m_2nd 4 bay layup different way 101 002.jpg
ID:	2125551   Click image for larger version
Name:	m_2nd 4 bay layup different way 101 003.jpg
ID:	2125552   Click image for larger version
Name:	m_2nd 4 bay layup different way 101 004.jpg
ID:	2125557   Click image for larger version
Name:	m_2nd 4 bay layup different way 101 005.jpg
Old 10-16-2015, 04:36 AM
  #569
FlyerInOKC
FlyerInOKC's Avatar
What a great idea Kevin!
Old 10-16-2015, 05:38 AM
  #570
Melchizedek
Thanks Mike, wish it (idea) were mine. It makes a great spreader. Don't cost nothing either.
Ok, The first 4 keepers are out of the mold and sized up. No bubbles on the rim.
This is the way I will proceed with the remainder of the blisters.
With a batch of keepers I can start bonding them to the cowl. This is where the fun begins. The culmination of a dream (fabrication of blistered cowl).
Kevin
Name:	First bubbleless four 102 001.JPG
ID:	2125625   Click image for larger version
Name:	First bubbleless four 102 002.JPG
ID:	2125626   Click image for larger version
Name:	First bubbleless four 102 003.JPG
Old 10-16-2015, 05:56 AM
  #571
FlyerInOKC
FlyerInOKC's Avatar
Now you will find out how uniform the circumference of the cowling leading edge is!
Old 10-16-2015, 12:47 PM
  #572
FlyerInOKC
FlyerInOKC's Avatar
New brotherhood if anyone is interested.
http://www.rcuniverse.com/forum/gold...otherhood.html
Old 10-18-2015, 10:12 AM
  #573
Melchizedek
My last two Minions (blisters) are in the mold and curing. At this point I have 9 Minions bonded to the cowl. I don't have any structural fast setting epoxy. So going the slow route setting them one at a time using gravity with a weight on top. Letting the epoxy jell then cleaning up the perimeter.
Won't be any pictures to post till they are all on. Later this week.
Kevin
Old 10-19-2015, 05:59 AM
  #574
Rocketman612
My Feedback: (85)
Rocketman612's Avatar
Kevin,
Looking good.
Pete
Old 10-20-2015, 02:21 AM
  #575
Melchizedek
Thanks Pete,
All the blisters are finally on,
https://www.youtube.com/watch?v=m7TSYimUz3A
https://www.youtube.com/watch?v=-A7SnW6O3tc
Kevin
Name:	m_Blisters 103 001.jpg
ID:	2126451   Click image for larger version
Name:	m_Blisters 103 002.jpg
ID:	2126452   Click image for larger version
Name:	m_Blisters 103 003.jpg
ID:	2126453   Click image for larger version
Name:	m_Blisters 103 004.jpg
ID:	2126454   Click image for larger version
Name:	m_Blisters 103 005.jpg
