Go Back  RCU Forums > RC Airplanes > Golden Age, Vintage & Antique RC
Reload this Page >
Gilmore Red Lion Build
Golden Age, Vintage & Antique RC Want to discuss some of those from the golden age, vintage rc planes or even an old classic antique vintage rc planes, radios, engines, etc? This is the place for you. Enjoy!
Old 10-20-2015, 02:30 AM
  #576
Dowmer
Dowmer's Avatar
Kevin, after all your time making this cowl, you should make a mold. Murphy's law says you'll need another. Lol
Old 10-20-2015, 03:12 AM
  #577
Melchizedek
Melchizedek's Avatar
Hi Downer Actually I have a mold of cowl without blisters and a mold for four blisters. The reason for not molding the cowl with blisters is the cowl was my first attempt at mold making. The blisters would have made it much to complex for my novice experience. After getting my feet wet. If I were to do it again I would mold them all together. That said, it is tempting to make a mold of completed cowl. Maybe before this build is done I will. But for now I will press on. After primer I intend to do rivets. Also considering a split cowl just like the replica.Kevin
Old 10-20-2015, 04:57 AM
  #578
FlyerInOKC
FlyerInOKC's Avatar
Great job Kevin! Just so you can get more experience molding cowlings with blisters I'll be happy to let you build my Ryan cowling. Hey, what are friends for if not to help you out?
Old 10-20-2015, 09:32 AM
  #579
Melchizedek
Thanks for the vote of confidence Mike However, as you can see from this thread I have tons of work looming.Kevin
Old 10-20-2015, 09:49 AM
  #580
FlyerInOKC
FlyerInOKC's Avatar
Can't blame a guy from trying!
Old 10-20-2015, 10:17 AM
  #581
Melchizedek
Guess not Never works with my boss lolThe domestic one especialy
Old 10-20-2015, 10:20 AM
  #582
Melchizedek
Please excuse my text format. RCU don't like my android.
Old 10-20-2015, 10:35 AM
  #583
FlyerInOKC
FlyerInOKC's Avatar
Must have been bribed by the fruit!
Old 10-20-2015, 12:30 PM
  #584
Melchizedek
Good one Mike, took me a second for that to click. Im slow sometimes
Kevin
Old 10-20-2015, 04:37 PM
  #585
Melchizedek
These two video's were originally included in post 575, only as links. Since there were no views on the links I think most weren't aware they were there. So If interested these are circular walk arounds of the cowl. One from the front one from behind. I did these cause it's hard to get a full view with just a couple of pictures.
Now there in an easy button.
https://www.youtube.com/watch?v=m7TSYimUz3A
https://www.youtube.com/watch?v=-A7SnW6O3tc Kevin
Old 10-20-2015, 06:44 PM
  #586
acerc
acerc's Avatar
Oh, yea, you just want to make sure everyone get's a look at your handy work! LOL....
Old 10-21-2015, 02:59 AM
  #587
Melchizedek
Yep, also with my slow connection it took me forever to upload them. Didn't want to have waisted that time. Besides, with my connection it takes alot of stamps. Kevin
Old 10-21-2015, 05:16 AM
  #588
FlyerInOKC
FlyerInOKC's Avatar
Beautiful work Kevin! A true work of art!
Old 10-21-2015, 06:58 AM
  #589
Melchizedek
What a great compliment Thanks Mike
Old 10-21-2015, 07:21 AM
  #590
FlyerInOKC
FlyerInOKC's Avatar
Just calling it the way I and everyone else here sees it!
Old 10-25-2015, 02:41 PM
  #591
Melchizedek
Finally got the landing gear matted to the spats and fairings. This had been a builder block for me. I set this aside along time ago cause I was stuck. Got back to it yesterday and was stuck again. Then I applied the game plane I use at work when the big picture on a job is out of focus. Start with what you can and the rest will fall into place. Bingo.
Hat tip to Robert aceRC, He suggested to use expanding insulation foam to lock the gear wire into the fairings and that is what I did. Caution if you use this method. It can blow your stuff up like microwave popcorn if you use to much. My fairings just got fat. Robert warned me about this. Use less than you think you need. I had to dig some out while it was still green till the fairings returned to there normal thin self. Captain lucky came ridding in and saved the day. It could have been a mess.
With the gear wire positioned in the jig (could not have done this without a jig) the inner spat half's and axils were put into place. Then the inside fairing half was bonded to the spat. Next the outer half was bonded to its mate and spat. Then expanding foam was let in carefully, Everything looked fine so went and watched tv for half an hour, Came back to check and the fairings were plump, then franticly dug foam out till the fairings returned to normal. Then gave micro squirts around the wire to make sure it was locked in. Then all was well. Then the lower end of the gear wire was locked to the inner spat with glass and a thickened epoxy mix.
Then maple strips were epoxied to the top of the gear mount being careful not to cover the mounting holes.
The maple strips will hold the gear in alignment so it can be set into the fuse and lined up when time comes.Mounting holes will be drilled then the maple strips will be ground off and gear set in it's home. Easy peasy.
This morning when all was cured the gear was removed from it's jig for the last time. Wheel and axle clearance was then determined. The opening is larger than I wanted but needed every bit to insert wheel with axle for mounting.
Once it was sure the clearance was going to work, then the outer half of the spat was bonded to the inner half. Then then reinforcing glass was laid on the inside spat seem. When that cured wheels were installed.
Eventually they will get panel lines and rivets.
Will be going back to building the air frame next. So glad the glass work is complete. Ready to move on.
Kevin
Name:	m_Gear assymbly     104 001.jpg
ID:	2127684   Click image for larger version
Name:	m_Gear assymbly 104 002.jpg
ID:	2127685   Click image for larger version
Name:	m_Gear assymbly 104 003.jpg
ID:	2127686   Click image for larger version
Name:	m_Gear assymbly 104 004.jpg
ID:	2127687   Click image for larger version
Name:	m_Gear assymbly 104 005.jpg
ID:	2127688   Click image for larger version
Name:	m_Gear assymbly 104 006.jpg
ID:	2127690   Click image for larger version
Name:	m_Gear assymbly 104 007.jpg
ID:	2127691   Click image for larger version
Name:	m_Gear assymbly 104 008.jpg
Name:	m_Gear assymbly 104 009.jpg
ID:	2127693   Click image for larger version
Name:	m_Gear assymbly 104 0010.jpg
ID:	2127694   Click image for larger version
Name:	m_Gear assymbly 104 011.jpg
Old 10-25-2015, 02:54 PM
  #592
stevegauth30
stevegauth30's Avatar
You make it look so easy, but i know that was a ton of work. You ought a be dang proud of em.
Old 10-25-2015, 05:02 PM
  #593
acerc
acerc's Avatar
My hat's off to you Kevin, they look great! And you know this was coming, "I told you so". LOL! But it is a great and lightweight method.
Old 10-25-2015, 05:05 PM
  #594
Melchizedek
Thanks Steve.
Yes I am very pleased with how they turned out. Believe me, this gear was a bugger for me. That's why I sat it aside for so long.
Makes me appreciate the few guys who put this stuff out commercially. Or the kits that have been engineered and go together well.
Thank you Robert, yes you did . If I hadn't been forewarned I'd of probably gone to bed thinking all was well. So glad I didn't. Can't tell you how glad.
Kevin
Old 10-25-2015, 06:01 PM
  #595
acerc
acerc's Avatar
I told you about the Jacuzzi. But filling a tractor tire was the worst thing one could imagine, it ended with a seriously huge bang in the middle of the night.
Old 10-25-2015, 06:12 PM
  #596
Melchizedek
All you can do is laugh at that one, then go buy a new tire.
Old 10-25-2015, 06:55 PM
  #597
acerc
acerc's Avatar
LOL! Yea! And rim, all in total $900 over a $4 can of foam idea.
Old 11-11-2015, 08:34 PM
  #598
Leroy Gardner
Kevin your glass work is impeccable, there's no way you could buy any thing even close to what you have done. One can only imagine what the rest of your plane will look like. You have wonderful skills many would like to have, self included. I guess there is no reason to say, keep up the good work, have a feeling you wouldn't have it any other way.
Leroy
Old 11-12-2015, 03:41 AM
  #599
Dowmer
Dowmer's Avatar
Kevin, great job. I know what a pain gear can be for golden age planes. I'll be making spats for my travel air mystery ship so wish me luck!
Old 11-12-2015, 06:13 AM
  #600
Melchizedek
Thank you Leroy.
So you know , I sweated it the whole way. This was uncharted waters for me. But that's the way I like it. Kind of like the runners high. You don't get the high without sweat and elbow grease.
Domer
I have been following your travel air mystery ship. Your gear is amazing. That gear would have deterred me from attempting that model. You made short work of it. It looks fabulous.
I will ask Captain Lucky to ride your way for your spats
And will be following along as well.
Kevin
