Golden Age, Vintage & Antique RC Want to discuss some of those from the golden age, vintage rc planes or even an old classic antique vintage rc planes, radios, engines, etc? This is the place for you. Enjoy!
WACO YMF
Old 09-23-2007, 10:16 PM
  #3676
skylarkmk1
skylarkmk1's Avatar
Default RE: WACO YMF
OK Guys,
I found a 1932 UBF-2 (NC 2091K) that has a cockpit similar to the detail drawing as supplied by Pica on the scale detail sheets. The first 3 pictures are the detail sheets whole. I will be breaking the sheets down and posting with matching photos and allow those who want to create a 1930s style cockpit as opposed to the newer cockpit of the YMF Classics and Supers. The Waco guys at CCA state that many of the cockpits of similar series Wacos were all similar, although wood was often substituted for metal on the IPs. P4 a, b, c, d, e & f are of the instrument panel. The Center Oval panel measures 9” tall x 16-3/4” wide on the full size, made from brass sheet with aluminum trim. The main panel is aluminum with Brown Crinkle Coat paint. The last picture is the front panel, just storage (glove-map) compartments. More to come… Anyone needing larger photos, PM me with your e-mail.
ID:	768783   Click image for larger version
ID:	768784   Click image for larger version
ID:	768785   Click image for larger version
ID:	768786   Click image for larger version
ID:	768787   Click image for larger version
ID:	768788   Click image for larger version
ID:	768789   Click image for larger version
ID:	768791   Click image for larger version
Old 09-23-2007, 10:55 PM
  #3677
skylarkmk1
skylarkmk1's Avatar
Jim,
You have a case of CRSA (Can't Read Stuff Anymore), many of us also have CRS (Can't Remember Stuff) that progresses day by day. Some days are better than others and I missed that little decimal point reading your post. Bill (stickbuilder) put his Waco on a diet as well, he will have to tell you what the results were, I can't find the posts right now (CRS kicking in).
Old 09-24-2007, 04:06 AM
  #3678
aminiet
aminiet's Avatar
John
Mr McCullough's model is correct in every detail I can see from all the pictures I seen.
You probably know, this type of aircraft was one of a kind and it crashed shortly after delivery to Cuba.
Angel
Old 09-24-2007, 09:39 AM
  #3679
skylarkmk1
skylarkmk1's Avatar
Angel,
You are correct that the Cuban S3HD-A was a one of a kind. There is another S3HD base in Vermont that is still flying, the Black fuselage, Yellow wings Waco based in Vermont, NC 14048. It was supposed to come to the AWC Fly In back in June, but time constraints made it impossible for this year.
ID:	769059   Click image for larger version
Old 09-24-2007, 10:13 AM
  #3680
skylarkmk1
skylarkmk1's Avatar
The Cockpit Floor areas: Rudder pedals; P1 Rudder drawing, P2/3 Rear Left and right rear pedals. There is a lot to see in the pictures. All the pedals of this style that I have seen have been chromed. The pedals pivot at the floor and have a triangular lever on the side to pull the cables, brake pedals and cylinders are inboard of the rudder pedal, Aileron and Elevator control rods (chrome tubes), scuff plates below the pedals. At the left side of P2 You can also see that the former is “laced” to the steel tube frame work with a flat woven “tape/string” and the pinking tape over the side stringer. Under the rudder pedals to the outside, you can see where the lower wing attachment struts enter the fuse and attach to the frame. The front seat belt attach point can also be seen at the top left center on the black seat support.
P4 Front Floor with Rudder pedals and upper part of the control stick. Note the aluminum panels at the front of the cockpit and no brakes[X(].
P5 Rear Floor and Rear control stick linkage
P6 Front control stick linkage, note bend in stick.
ID:	769070   Click image for larger version
ID:	769071   Click image for larger version
ID:	769072   Click image for larger version
ID:	769073   Click image for larger version
ID:	769074   Click image for larger version
Old 09-24-2007, 11:11 AM
  #3681
skylarkmk1
skylarkmk1's Avatar
Left Side Walls:
P1 Drawing
P2/3 Rear throttle quadrant (front similar). Mixture knob is in full rich setting.
P4 Left rear wall
P5 Front Throttle and door
P6 Front door closed
P7 Front door open, note rolled edge of the cockpit frame under the combing padding
ID:	769134   Click image for larger version
ID:	769135   Click image for larger version
ID:	769136   Click image for larger version
ID:	769137   Click image for larger version
ID:	769138   Click image for larger version
ID:	769139   Click image for larger version
Old 09-24-2007, 11:37 AM
  #3682
skylarkmk1
skylarkmk1's Avatar
Right side walls;
P1 Drawing
P2 Rear Right side with pitch control (crank) and heater control (“T” handle under instrument panel). Also “Rear Seat Solo” placard.
P3 Close up of pitch control and heater control
P4 Upper Rear Right side with light, pitch control and placard. Note the pink tape over stringers, gray color of fabric is from the aluminum undercoat and does not color the fabric under the pink tapes.
P5 Front Right side with pitch control
ID:	769161   Click image for larger version
ID:	769162   Click image for larger version
ID:	769163   Click image for larger version
ID:	769164   Click image for larger version
Old 09-24-2007, 11:54 AM
  #3683
skylarkmk1
skylarkmk1's Avatar
Guys,
Your collective help is needed. A few pages ago, I mentioned that scale functioning landing gear was under development. Dany from Team Genisis has asked Darrell Tenny at Sierra Giant to work on the gear and Darrell has indicated that he needs input from Waco YMF/UBF fans to see if there is enough interest to make the gear. Sierra is tops in making gear, much better than others. Once the drawings are complete, they can be scaled to whatever size is needed and the CNC machine can make the gear. Don't respond here, contact Darrel at www.sierragiant.com or 440-476-4885. Thanks.
Old 09-24-2007, 04:14 PM
  #3684
khodges
ORIGINAL: Stickbuilder
What size fuel tank are you using on your G-26 Ken?
I have a 16 oz tank on mine. I haven't flown more than ten minutes in any single flight on my UMF, and I have well over half a tank remaining when I pump it out. My guess is 15 to 20 minutes on 16 oz and still have a decent reserve. The -26 is a stingy little engine with gas.
Skylark--that Bf 108 Taifun, is that the same type that James Garner and his buddy stole in "The Great Escape"? Sure looks like it.
Old 09-24-2007, 04:40 PM
  #3685
skylarkmk1
skylarkmk1's Avatar
Ken,
I believe it is. Garner escaped with the forger who went blind. The one they got in the movie was plain grey, not half a pretty (and shinney Nightstalker) as this one is. Would like to see it outside and ready to go.
Old 09-24-2007, 05:29 PM
  #3686
aminiet
aminiet's Avatar
John, Ken
that was the same thing i was thinking
Angel
Old 09-24-2007, 07:47 PM
  #3687
khodges
I looked at the pic again of the Taifun; it really does look like the Escape plane, but seems to me, best I can remember, the main gear on the movie plane was either fixed, or a different retract. I don't remember the "109" style gear like this Taifun has. Maybe just variants of the same basic type.
Old 09-24-2007, 08:56 PM
  #3688
skylarkmk1
skylarkmk1's Avatar
From the research I have been able to briefly do, the Bf-108 Taifun was designed with retractable main gear from the beginning in 1934. The 108 continued to built after the war by Nord (France) as the Nord 1000. I can only speculate that Garner in his role as an escapee did not know how to retract the gear. But I seem to remember that just before they crash landed, the gear was up.
Old 09-24-2007, 10:38 PM
  #3689
skylarkmk1
skylarkmk1's Avatar
The seats;
P1/1a/1b Drawings
P2 Vertical view of the rear seat (Yes I know the bottom cushion is crooked, it is removable and I didn’t notice until later). Note the seat belts are between the sides and the cushions. No shoulder harness installed on this plane.
P3 Left side rear
P4 Right side rear
P5 Front seat (wide for one, very cozy for 2).
P6 Rear Head Rest, Front hear rest is similar, but with out top part. Front head rest can fold down for access to the rear instrument panel.
ID:	769555   Click image for larger version
ID:	769556   Click image for larger version
ID:	769557   Click image for larger version
ID:	769558   Click image for larger version
ID:	769559   Click image for larger version
ID:	769560   Click image for larger version
ID:	769561   Click image for larger version
Old 09-24-2007, 11:12 PM
  #3690
skylarkmk1
skylarkmk1's Avatar
Exterior Details as shown on plans
P1 Step Peg drawing
P2 Step Peg. This UBF-2 has an upper and lower step. YMF/UBF normally had just the upper only on the left side, and sometimes also on the right.
P3 Pitot Tube drawing
P4 Pitot Tube on UBF-2 NC 12002 (better picture)
P5/P6 Fuel Level Indicator and Fuel Line drawings
P7 Fuel Level Indicator (Indicates about 1/4 fuel left in tank)
P8 Fuel Lines
P9 Fuel Cap and Vent lines on upper wing center (UBF-2 NC 12002)
ID:	769594   Click image for larger version
ID:	769595   Click image for larger version
ID:	769596   Click image for larger version
ID:	769597   Click image for larger version
ID:	769598   Click image for larger version
ID:	769599   Click image for larger version
ID:	769600   Click image for larger version
Old 09-25-2007, 12:25 AM
  #3691
skylarkmk1
skylarkmk1's Avatar
Lights – Tail and Wing Tip
P1 Tail Light drawing
P2 Tail Light Photo
P3 Tail Light close up
P4 Tail Light close up from rear
P5 Wing Tip Light drawing (UBA and UBF-2 locations added by me)
P6 Wing Tip Light location – Right upper wing (same on YMF/UMF) on UBA NC 13041
P7 Wing Tip Light location – Left upper wing (same on YMF/UMF) on UBA NC 13041
P8 Left Wing Tip Light on UPF-7 NC 29927 for comparison
P9 Left Wing Tip light close up on UBF-2 NC 155Y (mounted as shown on drawing for the UBF-2). On this plane, during restoration the light was moved back to the tip apex from the location shown on the drawing for the YMF and as shown on the UBA.
That's the last of them folks. Any questions just ask.
ID:	769641   Click image for larger version
ID:	769642   Click image for larger version
ID:	769643   Click image for larger version
ID:	769644   Click image for larger version
ID:	769645   Click image for larger version
ID:	769646   Click image for larger version
ID:	769647   Click image for larger version
Old 09-25-2007, 12:58 AM
  #3692
skylarkmk1
skylarkmk1's Avatar
George and anyone else interested,
The eBay Waco kit went for $255.01.
Old 09-25-2007, 04:49 AM
  #3693
Stickbuilder
Stickbuilder's Avatar
ORIGINAL: skylarkmk1
I know, I bid it up for a while, and then asked myself, why. We can build those we have stashed, or now we can make our own kits. I would like to think that by enabling anyone to do their own, it has lowered the outrageous prices that they were bringing. Allowing for inflation, the $255.01 is not that far out of reason, considering that they were $180.00 when released. The last one on e-bay went for what, $355.00, or so? Of course, that one was pristine, while this one had been fooled with. Perhaps incomplete. I'm sure that the lady who was selling this one did not know whether it was complete or not.
Bill, AMA 4720
WACO Brotherhood #1
Old 09-25-2007, 06:42 PM
  #3694
ccrebidoux
You know, someone should send Cox a link to this thread. After 184 pages, you'd think MAYBE somebody would say, "you know we might have a demand for this kit, maybe we should start producing it again." DDDDUUUUUUHHHHH!
Chris
Old 09-25-2007, 09:21 PM
  #3695
Stickbuilder
ORIGINAL: ccrebidoux
Chris
Why would we want them to? They have given the plans to the AMA, and we have given the AMA the parts templates (full size). Order a set, and cut your own kit. It's much more fun that way. You can get all the hardware from other outlets, so there is nothing to hold you back, now is there? C'mon, give it a try.
Bill, AMA 4720
WACO Brotherhood #1
Old 09-26-2007, 08:36 AM
  #3696
SuperCub Man
John - Thanks tons for those closeup pix of cockpit and other details. They are invaluable!!
Old 09-26-2007, 12:08 PM
  #3697
Stickbuilder
Guys, I am embarassed. I have had these prints from the Pica Cockpit kit for years, and didn't think to post them. I really wish that I had.
Bill, AMA 4720
WACO Brotherhood #1
Old 09-26-2007, 07:23 PM
  #3698
Live Wire
Live Wire's Avatar
Well put your pants back on and get into the act
Old 09-26-2007, 07:54 PM
  #3699
Skinny Bob
My Feedback: (12)
Bill, you started this thread, you have kept a record of membership, you have contributed all of your model building experience, you have answered any and all questions of any member. Please don't feel bad about not posting the cockpit prints. If you where perfect I wouldn't like you!.
Old 09-26-2007, 08:14 PM
  #3700
skylarkmk1
skylarkmk1's Avatar
Guys,
I forgot a picture of the Magneto Switch and am adding a couple more for comparison.
P1 Magneto Switch from UBF-2 NC 2091K
P2/2a Instrument Panel from UFB-2 NC 155Y, completely different layout (plane was used for fuel testing) with some extra instruments/controls and paneled interior. Note filler pad in the rudder pedals.
P3 Instrument Panel from UBA NC 13041(s/n 3595). Different model type with similar Instrument Panel
P4 Forward exterior port side of cockpit area of UBA NC 13041. Note the “S” style control stick (similar to the plans sheet in post 3646). The UBA is a single, side by side, dual control, cockpit, was supposed to be “the Golfers Plane” with the forward storage for the golf clubs. “Don’t drive, fly to the golf course and play golf”.
P5 Instrument Panel from UBF-2 NC 12002, note the similar, but simpler layout
P6 Instrument panel from UBA NC 12445 (s/n 3598) with different panel (no oval and straight control sticks)
Conclusion - Even between aircraft of the same year, model, and nearly consecutive s/ns, variations/modifications are possible.
ID:	770894   Click image for larger version
ID:	770895   Click image for larger version
ID:	770896   Click image for larger version
ID:	770897   Click image for larger version
ID:	770898   Click image for larger version
ID:	770899   Click image for larger version
