WACO YMF
#3954
RE: WACO YMF
ORIGINAL: damifino
Thanks SuperCub Man, I have about 10+ hrs in it and there could be a little more (sanding and priming) done to make it really, really nice but.. enough's enough. By the time Brad messes with it and the end users prime and paint them the things will be as nice as can be. I have considered making paint masks for the blisters so two-toning the cowling will be a snap. What do you think, guys? Probably looking at $10.00-$12.00 per set for the masks......
Count me in.
Bill, AMA 4720
WACO Brotherhood #1
#3955
My Feedback: (22)
FL
RE: WACO YMF
where to start..first I was selling off an rc collection mostly giant scale but came across this white bipe.I wasn't sure but now understand its a pica waco ymf..it was flow by the former ownerand since he passed away I cant ask many questions and so here I am.It is in excellent shape and has no visible crash damage.theres some paint peeling off on the rudder fin.and the wings need some touch up with paint.the details are wonderful and a fellow modeler said dont touch anything it adds to the scale.I am going to update with my own electronics and it has an OS120 which seems to be a good match for it. the engine and its condition led me to think it flew alot and was allowed to sit a long time likely due to his medical health..I am going to pull the engine and make sure its in good working conditon.I dont want to do much to it as its scale is awesome and like I said a 120 should handle it well.
One of my concerns is the gap in elevator and rudder hinging.he used robart hinge points so at worst case scenario just cut them out and install new ones narrowing the gap..I dont want to generate any flutter but given the majestic speed I sort of dont think its a problem.but want to know what you guys think.. beyond the cosmetic work and upgrade in servos etc it is a beautiful ship and I hear it flies like a charm..I have 25 years of rc lol.but not much with bipes..by the number of posts in here I think I just entered a hallowed place and a legend.
#3957
RE: WACO YMF
ORIGINAL: cloudancer03
Bill, AMA 4720
WACO Brotherhood #1
#3958
RE: WACO YMF
Jay, the cowl is beautiful. If I keep skinning up the chin of mine, I'll need a new one some day. And the idea of a mask to paint the thing is genius. It took me over an hour to mask off the blisters on mine, using masking tape, the biggest PITA of the whole paint job. The time saving and convenience alone is worth the price.
Bill, I don't want to tell anyone how to build their plane, but I think you'll find how I did mine (carb orientation) is quite convenient. I think you'll love this little powerhouse, it hauls the Waco around great.
#3959
ON, CANADA
RE: WACO YMF
Jay - count me in on the masks. That's the only part I though might be a problem. I'm thinking of getting masks made for the Waco logo as well. Most names lettering etc could be done with vinyl. I'm sending ou some sizable art I got from the net. May be of use!
#3960
NC
RE: WACO YMF
A complete set of masks would not be out of the question, in other words, I will look into it. Stickbuilder, how about that original decal sheet you've got?
#3962
RE: WACO YMF
ORIGINAL: damifino
You say the word, and it's on it's way. I would be in for a set as well.
Bill, AMA 4720
WACO Brotherhood #1
#3963
RE: WACO YMF
ORIGINAL: khodges
I'm glad that you noticed that I had mine mounted differently. I removed the carb, and on closer inspection, found that the carb would never have pumped a drop of fuel. There is no pressure pulse slot available to the carb. mounted as I had it. I removed the metal arm and spring, and set mine up as you did yours. You probably saved me tons of headaches. You don't know how happy I am that you caught this.
Did you send your 26 out to Ralph for the Ignition change? I wonder if that would be worthwhile...It's probably expensive as all get out. I think that before I did that, I would do an engine swap, and just buy another G-26, but with the electronic ignition.
Bill, AMA 4720
WACO Brotherhood #1
#3964
NC
RE: WACO YMF
Hold on to your decal set for now LIVEWIRE.
Stickbuilder, Send that decal set up here and I'll get something worked up. The vinyl cutter has a material specifically for masking so this is not new territory as far as the process goes. Simply apply the mask, tape off everything else and you'll be ready to paint some crisp graphics. As with any masked stripe a light coat of the main color of the plane should be applied to the masked area to seal the edges from bleeding. Then apply your stripe color or a neutral color followed by the stripe color (if the stripe is lighter than the main color of the plane).
#3965
My Feedback: (22)
FL
RE: WACO YMF
stick...I will post a pic very soon.I just got the plane and marvelled at its classic lines..like I said most of the work is strictly cosmetic.the original builder was a very good builder.so the 120 is fine??as for the gaps I suspect they arent as bad as I described and I agree this is not a speed demon .I am looking foward to good ole fashiopn flying shooting touch and gos and a some sli[pping much like my big cub.
#3966
RE: WACO YMF
ORIGINAL: Stickbuilder
........set mine up as you did yours. You probably saved me tons of headaches. You don't know how happy I am that you caught this.
This engine isn't hard to start, especially after it's been run a while. It has capacitive discharge ignition, which puts a hotter spark to the plug and doesn't require quite as much of a prop flip to get enough from the magneto to fire the plug. My procedure to start it is to close the choke, switch off, throttle open, and give it a few quick flips to pull gas into the carb. Then I turn on the ignition switch, throttle full, and flip until it fires (usually three to five). Then open the choke, throttle at 1/4 or slightly less, and flip until it starts, usually twice or three times. This is for a cold start, once warmed up it usually takes one or two with the choke and then one or two without. I can't believe that EI would make it much easier to start, and then you have another battery to charge and worry about. The magneto engine will always run as long as there's gas in the tank.
Looks like you found the thread I was talking about. I was looking at doing this for a Super Decathlon I bought, because I really like the G-26, but I found another engine that served my needs without having to send it off for mods. My other concern for the Super D was a prop shaft long enough to allow the engine to clear the chin of the cowl. I certainly didn't want to cut it in front. I went with a BT32EI Fuji. Would have used the magneto version, but the flywheel is in front on the mag version and was afraid it would have rubbed the top of the cowl.
#3967
RE: WACO YMF
Ken,
I subscribe to that thread. It's called Lightening the G-26, and is in the Gas engine forum. I actually started to use my Fuji-Imvac BT-32 EI, on this one. It would have required serious cutting of the cowl, since the cylinder is longer than is the G-26, and due to the fact that the engine uses rear exhaust, which would have required cutting the entire bottom of the fuselage, and rebuilding it. I even considered using a 45 gasser which would have made for stupid power to weight, and I don't even want to consider a 3-D WACO.
I don't think that I will use the hand start on this, or any other gasser. I use the spring start feature on my G-62 engines (I know that the Torrington clutch robs a few RPM from the engine), but it is not offered on the 26. I will use my Big Bore electric starter for this one as well, since I don't relish the thought of a finger that close to an 18" prop.
Bill, AMA 4720
WACO Brotherhood #1
Bill, AMA 4720
WACO Brotherhood #1
#3971
ON, CANADA
1 Post
RE: WACO YMF
ORIGINAL: damifino
The cowling plug will be shipped Monday to Stan's Fibertech. He says he will begin work on a mold immediately. It may help move things along if the WACO Brothers who are interested were to call or e-mail Brad at Stan's expressing their interest. E-mail Brad at [email protected]
Here are a few pics.
#3972
WI
RE: WACO YMF
Joe ain't about to lend you no full scale Waco. He's seen your landings.
Joe
WB #54
#3973
RE: WACO YMF
ORIGINAL: WacoJoe
Gee, I don't know Bill. Maybe his landings are better than mine!! [X(]
Joe
WB #54
Joe
WB #54
Bill, AMA 4720
WACO Brotherhood #1
#3975
NC
RE: WACO YMF
The masks I first thought about are to mask off an entire cowl blister, one at a time, for the two-tone scheme seen on a lot of WACO's. That mask set will have to be made to fit a particular cowl (such as the one Aerofibertech) is making because it must fit the transition from blisters to cowling precisely. Now, the 'hammerhead' looking design on every blister as seen on the PICA box art is the next thing to think about. That is what I'm going to look into as soon as I recieve Stickbuilder's PICA decal sheet. Best case on this deal will be a complete set of paint masks based on the PICA 1/5 scale decal set, including WACO logos, 2 different blister masks and everthing else that is on the PICA WACO sheet. Hope to have some info on pricing the mask set in a couple of weeks.
A scaled-up set should be no problem except for the complete blister masks, because they have to fit the blister transitions precisely.
