WACO YMF
#427
ON, CANADA
RE: WACO YMF
ORIGINAL: Hughes500E
Yall are getting interesting here [8D]
How about this, it's labeled as a UPF-7 [] ?????
http://www.rcuniverse.com/magazine/a...article_id=563
#428
RE: WACO YMF
ORIGINAL: Stickbuilder
After putting on the Koverall, I aded the feet and fairings, enclosing the 4th side with a piece of balsa. Did I mention that I had tacked the 4th side already, and sanded the fairings to shape? If not, that is what I did. After installing the fairings, I blended the feet and fairings, using lightweight spackle, and then sanded them to shape. I finished them with several coats of nitrate dope, and then primed and painted everything as a unit. Hope that clears this up for you.
Bill, AMA 4720
WACO Brotherhood #1
Bill, AMA 4720
WACO Brotherhood #1
I tried to comment on how good your model looked with the trim colours but timed out and lost a rambling response saying how much I admired the result.
I have read of using "lightweight spackle" before but at that time i didn't know what it was. After some thought and because I was decorating the hall and stairway in my house I went to the local "Do it Yourself" emporium. I bought a number of tubs of plaster filler and found the equivalent material for us here in UK. It is available here from "Polycell" as a "No Sanding Polyfilla". Not only is it brilliant for finishing plaster walls it will sand easily. The tub feels empty the contents are so light. I have used vehicle Body Repair products before, Polyurethane Filler but it doesn't match balsa, too hard when sanding. The "No Sand Polyfilla" is really useful. I damaged the wall with a ladder after I had covered the plaster with lining paper. The spackle filled the damage easily with a damp spreader and sanded afterwards without damaging the paper.This clarification may help my countrymen when they read your comments.
I bought half a dozen packs of Koverall from Australia but haven't used it yet, have you any hints on covering with it please?
old git - - - - - - - aka John L.
#429
RE: WACO YMF
ORIGINAL: pimmnz
Weather has been bad, everyone is talking about building, then someone sent me this... I know Bill don't care for UPF's, but it's a Waco after all...
Evan.
Evan.
Bill, AMA 4720
WACO Brotherhood #1
#430
RE: WACO YMF
Well, John,
When preparing to cover with Koverall, you want to make sure that the framework tohat is to be covered is sanded sompletely smooth, and that it is as clean as you can possibly get it. Next, I apply 3 full wet coats of Nitrate clear dope to the framework, sanding between each coat, and cleaning the framework after sanding. Once you have the 3rd coat of dome on the framework, and th sanding is finished, and you have cleaned the framework, clean it again.
Cut a piece of the Koverall slightly larger than the framework upon which you wish to cover. Lay the material on the framework, making sure that the weave runs with the frame, and not on the bias. Using a small brush dipped in lacquer thinner, run the brush along the first edge of the framework, wetting the fabric. Take your finger and rub the fabric into the framework (use the ball of your forefinger to do this. The dope on the framework will be wetted, and the material will adhere to the frame. Try to pull the wrinkles out as you go, and before long, you will have a covered panel. Trim the excess oway (use a new single edge razor blade for this, since it is sharper than an X-acto blade. If you need to lap another piece to th first one, rough cut it, and finish cutting with pinking shears. overlap the piece at least 1/4" and lock it down with dope thinned 50/50 using the lacquer thinner. Once the framework is covered, you may begin applying heat using either an iron, or a heat gun. Do not stay in one spot too long, and before long, you will have a tight fabric covered panel. Apply 3 coats of the thinned Nitrate dope to seal the fabric, and then apply the finish of your choice. I'll be doing something before you need to do this, so I'll walk you through the proceedure with pictures.
Bill, AMA 4720
WACO Brotherhood #1
Bill, AMA 4720
WACO Brotherhood #1
#431
My Feedback: (63)
RE: WACO YMF
I will take your word that you believe it is overpowered with an q35. I did however spend many weeks on the net communicating with anyone I could find who had this plane. I spoke with at least 10 people. Most thought it was underpowered with a 1.2 and I was surprised how many I found who were using a q35 or q40. One guy had a q50 in his and thought it was what he needed. Maybe he was looking for vertical performance.
I am powering it based on my research and not on experience. I do not expect it to fly like a trainer. I sure hope this plane flys different than my other bipes. It would be boring if all my planes flew the same. I always hope that every new project advances both my building and flying skills. That is why I build them, because when I crash em I can fix em.
ARF's are killing the hobby for this reason. They have one bad crash and they are out of the hobby for good because they do not know what to do with the pieces.
____________________________________
Smooth seas never made a good sailor
Waco brotherhood#7
Waco brotherhood#7
#432
My Feedback: (16)
BC, CANADA
RE: WACO YMF
I really like the Kangke ARF, it looks great. It does not however look like any other UPF-7 that I have seen. If a guy attempts to locate plans for it, you'll get the less than desirable UPF-7 that was first posted []
I don't get it! What am I missing was the point of posting that ARF picture!
#434
RE: WACO YMF
I have seen some of the Waco ARF's and the UPF ones seem to be modelled on the heavily modified Franklin version. The only plans I have are the Carlsson drawings and it looks like the red flying one a few posts ago...
Evan.
Evan.
#436
RE: WACO YMF
Hi Bill,
Thanks for the "Heads up" on covering with Koverall, I will keep a look out for your posts. I already think you answered a problem I found using Nylon on a root rib, insufficient coats of dope on the structure in the first place. I have seen Balsaloc? mentioned elsewhere, have you any experience with it? I don't know if it is available in UK but "tHat" auction site would probably serve that need, if indeed it were worth pursuing.
old git - - - - - - aka John L.
#437
RE: WACO YMF
I don't use Stix-it, nor do i use BalsaLoc. As I said, 3 coats of nitrate dope, and apply the Koverall with either lacquer thinner, or thinned nitrate dope. Both work equally well. Stix-it is a thermally bonding chemical (you have to add heat) The Dry-Heat Shrinkage factor is several percentage points. You will probably have started the Polymer to begin to react to the heat along the application line, and that may create a pucker adjacent the adhesion point. The nitrate works extremely well, so why bugger with a good thing?
Bill, AMA 4720
WACO Brotherhood #1
Bill, AMA 4720
WACO Brotherhood #1
#439
My Feedback: (63)
RE: WACO YMF
That spakle was a good idea for filling in the wing fillets. I did not know about that product. After 40 years of building it makes me feel kinda stupid. I had been using lightweight body filler or glass and cloth for such things. That spackle was superior to both for that particular application. Much lighter, less work.
thanks
thanks
#440
RE: WACO YMF
ORIGINAL: ronj10
thanks
thanks
Bill, AMA 4720
WACO Brotherhood #1
#441
TX
RE: WACO YMF
Hi Fellows;
Stickbuilder invited me over,even if, I am assembling a Cox Pica 1/5 scale YMF-5 ARF. He said he thought the # 8 was avaliable in the brotherhood. I would like to have it if it's not taken. I built a Waco YMF-5 from a PIca kit about 15 yrs. ago and lost it on the maiden flight from interference from another radio. Spent nearly a year building that plane. I almost gave the hobby up after,but I recovered. Glad to be part of your group.
Gaines
Gaines
#442
RE: WACO YMF
Gaines,
I posted the Differential information for you in your thread. Welcome aboard. Grab a number and have fun
Bill, AMA 4720
WACo Brotherhood #1
Bill, AMA 4720
WACo Brotherhood #1
#445
RE: WACO YMF
HI BILL, YOUR WACO LOOKS EXCELLENT BUT THEN I WOULD EXPECT NOTHING LESS FROM YOU. I DONT KNOW WHAT YOUR DOCUMENTATION SHOWS BUT I HAVE SEEN SOME WACOS
WITH THE BLISTERS ON THE COWL PAINTED TO MATCH THE TRIM ON THE AIRPLANE(GOLD).
GREAT JOB AS USUAL.
SEE YOU SOON
YOUR FRIEND
BENJAMIN HOWARD BIRCHFIELD THE 3RD
GREAT JOB AS USUAL.
SEE YOU SOON
YOUR FRIEND
#447
RE: WACO YMF
Benjamin,
You write as if a friend to Bill but I feel you are in fact a false friend.
Whilst I agree with your aethetic appreciation of adding decoration
around the streamlined humps that accommodate the rockers on his
model I personally have issues with your suggestion.
I have a ΒΌ scale Mr Mulligan kit with a similarly configured cowl. As a result I
have been unable to do much more than open the box for fear of eventually needing
to produce a simple BACKGROUND finish around said humps.
Least said soonest mended.
old git - - - - - aka John L.
ORIGINAL: BHB3
GREAT JOB AS USUAL.
SEE YOU SOON
YOUR FRIEND
GREAT JOB AS USUAL.
SEE YOU SOON
YOUR FRIEND
#449
RE: WACO YMF
ORIGINAL: old git
Benjamin,
Benjamin,
ORIGINAL: BHB3
GREAT JOB AS USUAL.
SEE YOU SOON
YOUR FRIEND
GREAT JOB AS USUAL.
SEE YOU SOON
YOUR FRIEND
Benjamin is probably the best friend that I have in this world. We have been friends and enjoyed this hobby together for more than 40 years, and he is definately not a false friend. If Benny wants to see gold on the rocker blisters, then gold they will be. I never let a little work stand in the way of progress.
Bill, AMA 4720
WACOBrotherhood #1
