WACO YMF
RE: WACO YMF
ORIGINAL: Dash7ATP
Hi Bill,
I knew those fairings were junk as soon as I saw them. I've never seen anything like the stuff they were made of either. Kinda of fuzzy on the inside surface.
I have been looking for your details on fairings but haven't been aboe to find them. Would you remember which page or post I might find that on?
Thanks.
Joe
ORIGINAL: Stickbuilder
I tried to get operating main gear for the fifth scale, but got suckered by Darryl at Sierra Giant Scale instead. This Friday will be 4 years that I'm waiting for the gear to ship. He did promise that it would ship on Friday. I'll be doing my own for the 27%.
Joe, trash those plastic fairings and make yours like I showed back in the thread. They look perfect, and are easy to do.
Bill, Waco Brother #1
Thanks.
Joe
Have a look on page 7.
RE: WACO YMF
Ah Ha! That is indeed simple enough. Ithihnk I'l just use the stuff in the kit for the ourlines of the fairings for starters and see how it matches the full size model I'm coping.
As for power, I'm kinda bummed out right now. I have two YS1.20s I really like. One is an earlier version but it still runs great and sounds wonderful. Imeasured from the center of the shaft to the top of the rockers yesterday and Ican't use it without cutting an opening in the cowl. It's about 4.5 inches high, and the cowl has an 8.5 inch Diameter. Idon't think it will fit into a rocker arm blister. Shucks!
Joe
Banned
RE: WACO YMF
"I don't think it will fit into a rocker arm blister. Shucks! "
I went through that with my first Waco, gave up, but the bullet, laid the engine at 9 oclock, and cut a hole in the cowl.
Les
Les
RE: WACO YMF
ORIGINAL: LesUyeda
Les
Les
I just had an idea . Since the headappears to be about a 1/4" too high, I could cut the openingjust big enough to clear the rocker cover on the YS and make a seperate "double blister" just large enough to cover it. If done right, it could look like a "Mod" to the real one.
Another quick question to the experienced Pros on this elete forum. It appears that the thrust washer on my YS may be too close to the front of the lifter tubes to allow for a good dummy engine. Is there anyone who makes an extension Icould use that will allow me to mount the engine back far enough to mount a complete dummy in front of it? Iguess the standard way is to just use the engine as one of the cylinders of the "dummy" and be done with it. I'm thinking about the AeroTech as Ihave one of theirs in my Yellow Aircraft P-47.
Thanks all.
Joe
FL
RE: WACO YMF
BOY! after reading more of the post on this thread,I feel like a hair in a bowl of soup!!! Please,forgive my lack of understanding. You see, I was trying to find others on RCU that have assembled and flown the same plane (ARF) that I've recently aquirred.I realize now that this is a builders thread,and because of my lack of experience,I know I don't have anything to add hear. I became involved in this wonderful hobby 4yrs ago,and as of yet havent built a model from a kit yet. I do have a cub kit .60 size,from great planes and I've also got a vintage Sig cougar kit wating as well.But as things are to date I have rebuilt 15 various models that I rescued from the trash can at the club I belong to.but all of them were arf models to begin with. I think I'll check back in,in about 5yrs when I've attained a decent amount of stick building experience. PLease forgive my indescretion, thanks
RE: WACO YMF
RCJunky,
Don't dispair!And don't just go away. This site and thread is a wealth of info for anyone with an interest in WACOs, or just scale models. As for not building, you have in the old Sig Kadet one of the best "first time" builder's kit's out there. I don't know how old your kit is but in my opinion, it can't be too old if it's the Kadet. My first RCPlane was a Kadet around 1978 and that was Before ARFs. Rebuilding OPCs (other peoples crashes) is also a good way to gain experience in building. Basically, it's all about gluing balsa together. What seperates the good ones from the hackers is how well you ensure the parts fit properly before you hit it with CA. You just have to take a few minutes longer to do it right the first time. Like my Dad used to say, "measure twice and cut once". The same thing applies to building a model.
For what it's worth, there is an extensive thread within this thread on a gentleman's (no offense intended) bashing of theCOX (I think)WACO ARF into a very nice scale model. Now some will say that once an ARF, always an ARF. But his certainly won't look like it when finished. Heck, given the age of this forum, it may have already been finished. I'm just not sure about that.
Welcome aboard.
Joe
Welcome aboard.
Joe
RE: WACO YMF
RCJunky,
OOPS! I jsut re-read your post and noticed you had said you had a Sig Cougar instead of a Kadet. That is still a very good kit, but Idon't recall if it had a foam wing or not. I do know it was a good flying model as several friends of mine had them and loved them. Give it a try. You'll like it!
Joe
Joe
RE: WACO YMF
The sig cougar is a great plane. Unfortunately mine sucommed to a bad cell in the battery. It does have a foam wing with 1/64 balsa sheeting
as I recall it is a mid wing. The cavalier is also a mid wing with very long and spindly landing gear. There is one more in the series but I can not recall the name of it, and I think it was a low wing. Possibly the patriot. Regardless of the name they are all very aerobatic but stable planes
My Feedback: (7)
RE: WACO YMF
ORIGINAL: Dash7ATP
My first RC Plane was a Kadet around 1978 and that was Before ARFs.
RE: WACO YMF
ORIGINAL: iflyj3
If I may interject a correction. Linear had ARF's out the the late 60's. Approximately 1967 if my memory serves me. The fuselage was ABS plastic over a plywood skeleton with foam wings. I think there were 3 or 4 of them at that time.
ORIGINAL: Dash7ATP
BTW, Iliked my MicroPro 8000 as well. Way before it's time. Ifinally got rid of my two a few years ago.
Joe
RE: WACO YMF
ORIGINAL: rcjunky67
Trust me, not one member of the Brotherhood was a born modeller. We all had to learn, and that is the purpose for this thread. We toss out ideas, some good, some crap, and they are vetted by the membership.
Stay with us, and hang in there. You can scale out your GP (just be careful about adding weight).
Look at what Dan has been able to accomplish with his Waco. His is/was the first one built from plans with our templates. He has had a few brushes with terra firma but has come back strong with the most scale wing and wingtip yet. You can do it too.
RE: WACO YMF
NEW BROTHER ALERT !!!!
RCjunky67 is our newest Brother. He is Brother #222. Let's all welcome him
Junky, with a triple deuce number, you gotta just hang tough and stay along for the ride.
RE: WACO YMF
ORIGINAL: Dash7ATP
Damn!
I just had an idea . Since the head appears to be about a 1/4'' too high, I could cut the opening just big enough to clear the rocker cover on the YS and make a seperate ''double blister'' just large enough to cover it. If done right, it could look like a ''Mod'' to the real one.
Another quick question to the experienced Pros on this elete forum. It appears that the thrust washer on my YS may be too close to the front of the lifter tubes to allow for a good dummy engine. Is there anyone who makes an extension I could use that will allow me to mount the engine back far enough to mount a complete dummy in front of it? I guess the standard way is to just use the engine as one of the cylinders of the ''dummy'' and be done with it. I'm thinking about the AeroTech as I have one of theirs in my Yellow Aircraft P-47.
Thanks all.
Joe
ORIGINAL: LesUyeda
''I don't think it will fit into a rocker arm blister. Shucks! ''
Les
Les
Thanks all.
Joe
Just bite the bullet and get your mitts on an OS FT-160. They are the perfect engine for this model, and require no cutting of the cowl at all (well, you will need a couple of small holes for the exhaust. They run well on FAI fuel, and you can brew that up in your garage.
RE: WACO YMF
[/quote]
Damn!
I just had an idea . Since the headappears to be about a 1/4'' too high, I could cut the openingjust big enough to clear the rocker cover on the YS and make a seperate ''double blister'' just large enough to cover it. If done right, it could look like a ''Mod'' to the real one.
Another quick question to the experienced Pros on this elete forum. It appears that the thrust washer on my YS may be too close to the front of the lifter tubes to allow for a good dummy engine. Is there anyone who makes an extension Icould use that will allow me to mount the engine back far enough to mount a complete dummy in front of it? Iguess the standard way is to just use the engine as one of the cylinders of the ''dummy'' and be done with it. I'm thinking about the AeroTech as Ihave one of theirs in my Yellow Aircraft P-47.
Thanks all.
Joe
[/quote]
Joe,
[/quote]
I'll trade you a YS 1.20 for an OS1.60 twin.
Joe
My Feedback: (48)
RE: WACO YMF
RCjunky
Welcome to the Brotherhood.
Bill,
You are so right when you say no one is born a modeler. I remember the day we first met and talked Waco I thought I could never build a Waco from plans but you and the Brotherhood got me through the build. It’s been a busy month something going on every weekend so I haven’t had to much time to build I hope to have the top wing framed up by Top Gun so you can check them out. See you soon.
Bill,
FL
RE: WACO YMF
Thank's for the welcome.I don't really know what I have to offer,but I realize I've got so much to learn. This thread is the most amazing reading that I've found so far. And the more I read, the more I also realise,this is more like a family in some way's... I hope to one day be able to build a true scale kit of one of these beautiful planes. As is probably typical,with all this killer info at hand ,I'll probably get in over my head before to long. The great planes ymf is a fun, or stand off scale model out of the box. And it will be a test bed in a lot of way's. I mean, I will try to make alot of changes to add scale to it , but being an arf, I will be somewhat limited. It's not my first bipe, but it is my first waco. I don't have to tell anyone here how beautiful these aircraft truly are. And one day ,hopefully with all your help, I will be able to do one justice with a real kit. Thank you agin for the welcome...
RE: WACO YMF
Welcome rcjunky67. You are absolutely right. This is a family of sort's. And all that is required is the love of the Waco. Welcome aboard brother, enjoy.
RE: WACO YMF
I'm getting anxious to start my build, and that starts with the wings. Somewhere in the many posts I have read here is mention of plans to modify the wing tips for a much more scale like appearance. I am planning to redesign mine, but there is no point in re-inventing the wheel. If these plans have been posted, I haven't found them yet. Help!
Joe
Joe
My Feedback: (48)
RE: WACO YMF
ORIGINAL: Dash7ATP
Joe
Joe
If you go back to page 574 you can see the progress I’ve made on the wing tips. Bill has helped me with this mod and John has provided the pictures of the full size wings I think there pretty close.
RE: WACO YMF
ORIGINAL: mrdhud
Joe,
ORIGINAL: Dash7ATP
Joe
Joe
Joe
