Golden Age, Vintage & Antique RC Want to discuss some of those from the golden age, vintage rc planes or even an old classic antique vintage rc planes, radios, engines, etc? This is the place for you. Enjoy!
WACO YMF
Old 01-04-2013, 07:01 AM
  #15851
hopkimf
My Feedback: (56)
Default RE: WACO YMF
Anthony and Joe,
Thanks, I'm going to coat the Monocoupe with PolyC. It is glow right now, but I think I'll put a G-26 on it. Moving away from glow.
Old 01-04-2013, 11:44 AM
  #15852
jlhambright
jlhambright's Avatar
Hi all, this is one of the things I like about golden era aircraft, the nice curves. I wasn't sure of the thickness, guess I will sand until it looks right after framing. Here's my supervisors. This is the first time I've posted photos, not sure if they will go with this message
ID:	1836696   Click image for larger version
Old 01-04-2013, 11:46 AM
  #15853
jlhambright
Well guess they went with the message.
John, Waco Brother #232
Old 01-05-2013, 06:51 AM
  #15854
hopkimf
My Feedback: (56)
For Barth 1/3 YMF LE sheeting I picked up ideas from Aminiet, Chuck L and Anthony. Method took three phases: 1. glue and clamp sheeting to spar and let dry, 2. soak with amonia-water mix, wrap with 2 inch masking tape and let dry. 3. Rough cut sheeting to wingtip radius, soak and tape. Worked slick. Better than my clamps, tie wraps, weights, etc. I've done this many times before, but always with smaller models and thinner sheeting that bent more easily.
These forums are really helpful. Thanks.
Mike Hopkins Waco Brotherhood # 132
Old 01-05-2013, 07:33 AM
  #15855
jlhambright
Thanks Mike, that helps a lot, I've always had trouble with sheeting over compound curves.
John, AMA 601984, Waco Brotherhood 232
Old 01-05-2013, 08:52 AM
  #15856
chuck l
My Feedback: (17)
ORIGINAL: mogman
Mike,
As well as wetting the sheeting to go around the leading edge, you can also set your monocote iron on high and use that to steam the sheeting to ease the bending. Works well with thin plywood as well.
You can also ''dry glue and iron'' the sheeting. Put a thin coat of white carpenters glue on both surfaces, let dry 5-10 mins., place wood in position, wet and iron with a hot (300') monocote iron. The heat softens the glue and then thermo-sets it. No taping, no waiting for glue to set. Just hold the part for 15-20 seconds...all done. If you have to remove the sheeting (within a reasonable time), simply re-heat and gently pull away, re-position, re-heat and good to go. I've just finished sheeting a large glider fuse with 1/64 ply panels using that method...works a treat!!
Cheers,
Dave.
W/B #180
Dave,
Does using the heat method decrease the adhesive strength as compared to the regular procedure of using the glue?
Chuck
Old 01-05-2013, 09:07 AM
  #15857
mogman
mogman's Avatar
HI Chuck.
I tried to remove a test piece of 1/64 ply that I had ironed on, after an hour or so, and it tore the wood. As far as I'm concerned, the glue joint is as good either way.
Cheers.
Dave.
W/B #180
Old 01-06-2013, 01:23 PM
  #15858
chuck l
My Feedback: (17)
I've covered the stab and fin with Solartex but have a question. When covering something like a wing, do you firmly attach the covering to the ribs by rubbing it down with your fingers as you would around the perimeter?
Chuck
Old 01-06-2013, 03:23 PM
  #15859
acerc
acerc's Avatar
I personally say no! Let what ever naturally attaches while shrinking be it. This keeps the covering even through out. And believe me it will attach plenty.
Old 01-06-2013, 04:47 PM
  #15860
RCplanman
My Feedback: (16)
CHUCK 1,When I use Solor or World Tex I just iron it down. I have found that it's better to shrink it with the iron and not the hot air gun whitch can be overdone.Thats what works for me. Bill
Old 01-06-2013, 04:50 PM
  #15861
hopkimf
My Feedback: (56)
Chuck L,
Here are a few photos of old Monocoupe covered in Solartex. I just went around the perimeter for all the surfaces. The covering adhered well. Also used heat gun to shrink fabric instead of the iron.
ID:	1837594   Click image for larger version
ID:	1837595   Click image for larger version
Old 01-07-2013, 03:38 PM
  #15862
hopkimf
My Feedback: (56)
ORIGINAL: hopkimf
Forgot to mention I wrapped the LE sheeting for wingtips with the 2 inch tape and had it covered like a mummy. It took forever to set using Titebond. Not much open area for moisture to evaporate. Pulled the tape too early on two and had to redo.
Old 01-08-2013, 02:54 PM
  #15863
WacoNut
WacoNut's Avatar
My Waco is getting close to being ready to cover. Went much faster than I thought it would.
Later!!
Anthony
ID:	1838315   Click image for larger version
Old 01-08-2013, 04:21 PM
  #15864
hopkimf
My Feedback: (56)
Nice work!
Old 01-08-2013, 04:34 PM
  #15865
WacoNut
WacoNut's Avatar
Thanks Mike,
Much easier the 2nd time around
Later!!
Anthony
Old 01-08-2013, 11:11 PM
  #15866
Errol Levin
Errol Levin's Avatar
Hi Anthony
Looks great. Please be so kind as to post some close up pics of the coaming so I can see how you did it. I have to do mine, and if you don't mind, I need some ideas.
Best regards and compliments of the season to all.
ERROL #204
Old 01-09-2013, 02:58 PM
  #15867
WacoNut
WacoNut's Avatar
Errol,
I will get you some pics tomorrow, you can also check out my build thread on the Waco in the R/C Scale Aircraft forum.
I put a piece of black rubber hose(automotive gas line) around the cockpit opening and then glued down vinyl over he top of that to simulate the coaming. I then drilled pilot holes around the perimeter and added the sticthing thru those holes. Worked pretty good.
Later!!
Anthony
Old 01-09-2013, 05:16 PM
  #15868
Dash7ATP
Dash7ATP's Avatar
ORIGINAL: WacoNut
Errol,
Later!!
Anthony
Obviously this is not 1/5 Scale! I was wondering how to do my coaming. This is a good idea but will be much more difficult at the smaller size.
I think I would have waited until I have finished painting it prior to doing the coaming. That's what I'm doing. Hope I don't screw it up!
It's looking good!
Joe
Old 01-09-2013, 05:42 PM
  #15869
WacoNut
WacoNut's Avatar
Joe mine is 1/3 scale. I did mine after painting and the hood on the plane is fiberglass.
I have seen other guys on here do very similar with the 1/5 scale as well. If you strip the backing off the vinyl it becomes very pliable and easy to work with. I am sure you can do the same with the 1/5 scale.
I crashed my Waco back in the spring and I am building a new fuselage. All the wood in the fuse is new and I am using the fiberglass parts from the old fuse except the cowling which was damaged beyond repair. I am hoping to leave the cockpit coaming intact and mask it off when I repaint the plane. Will have to wait and see how that works out. Any other plane and I would probably have scrapped it out, just loved the Waco too much.
Later!!
Anthony
Old 01-09-2013, 08:32 PM
  #15870
Dash7ATP
Dash7ATP's Avatar
ORIGINAL: WacoNut
Later!!
Anthony
I understand your feelings on the Waco. I have been working on mine pretty much every day since I got the kit in early May. My wife is pretty much sick of it.........."I'll be glad when you are finished with that plane! I never see you anymore!" It is beginning to get a little old.
I have three to four coats of Nitrate all over and two coats of PolyC on the wings over three coats of nitrate.. I still haven't decided on what to use for the final finish. I'm very familiar with KlasKote, but have heard about how well the auto Base coat, Clear coat works. I haven't tried that yet. Will it go over the PolyC or dope OK? Any experience with that?
Latex is a consideration, but I'm concerned about the masking tape lifting it whild doing the trim.
decisions, decisions!
Joe
Old 01-10-2013, 11:45 AM
  #15871
mrdhud
My Feedback: (48)
mrdhud's Avatar
Bill,
Here’s the information on the fly in next month. I’m planning on attending Saturday hope you can make it as well as any one else close by.
http://delandrcclub.com/
Old 01-10-2013, 12:49 PM
  #15872
VOX
VOX's Avatar
Hello,
My project has moved forward a bit.
Shape of the fuselage and cockpit now has the correct shape.
Albert
ID:	1838922   Click image for larger version
ID:	1838923   Click image for larger version
Old 01-10-2013, 02:57 PM
  #15873
RCplanman
My Feedback: (16)
Joe, The MAN on Latex is Roy Vallencourt. I would have the same concern, except you seem to have a good base.
If you ask him I'd be interested in his answer.
Bill
WB 126
Old 01-10-2013, 03:04 PM
  #15874
WacoNut
WacoNut's Avatar
Joe,
Latex can be a little of a pain with masking. It is all in the timing of removing the mask. Either very soon after painting or several days to give the layers time to cure out. I prefer removing the mask as soon as it sets.
I have had good compatablity with PolyC with Dupli-Color high fill primer. I am pretty sure I am going to try base coat/clear coat on the Waco this time around. Latex will not give you a good glossy finsih. I want a gloss finish this time around.
Later!!
Anthony
Old 01-10-2013, 04:41 PM
  #15875
Dash7ATP
Dash7ATP's Avatar
Anthony,
Is the Dupli-Color a lacquer based primer? If not, what is it?
Joe
