WACO YMF
#1701
RE: WACO YMF
Jim,
I only use Koverall (SIG) and Nitrate dope, followed by automotive finishing systems. I'm sure that there are other things out there that would work just as well.
Bill, AMA 4720
WACO Brotherhood #1
Bill, AMA 4720
WACO Brotherhood #1
#1702
RE: WACO YMF
Jim, I use my heat gun and heat the stuff as I pull, it usually comes off, color layer and all. If I have remnants of the color layer that outlast sanding the surface smooth, I figure the new covering , or the paint that goes on it, will cover it up. The only coverings I use are Solartex and Koverall.
Skyjet--I figure that once I have the needles set, they won't need fooling with, so I'm not gonna worry about them. I haven't adjusted the needles on my US 41 powered plane in over a year. What I am trying to figure out is how to work the choke. I can accept the holes for the plug/wire, they're underneath, but I don't want to make any more holes on the sides of that nice cowl. I am working on an idea, but want to test it before I decide.
I finally got the dummy trimmed to clear the engine and recess it enough to make it look good. Someone earlier said something about it looking bad if the engine is "shoved" against the front of the cowl, and I agree. Ideally, if I could have found a propshaft 1/2 inch longer than what the G-26 came with, it would have been perfect. At any rate, I made an alignment "jig" and mounted the dummy in the cowl this afternoon. It consisted of cutting pieces of lite ply and epoxying them to the rear of the cylinders; these pieces extend to the inside surface of the cowl and are epoxied in place. I then fiberglassed the seams, and reinforced the ring at the rear used to attach the cowl to the fuse with more fiberglass. I also added some baffles between cylinders 6, 7, 1, 2, and 3 to fill in the gaps between cylinders (full scale also has them). I can still get to the screws holding the cowl on easily.It's out in the garage (shop) drying now. I'll post some pics tomorrow.
NOW, maybe I can get some covering done That, panelling the forward fuse, rib tapes, paint, trim and final assembly are about all that's left.
#1703
RE: WACO YMF
I rebuilt the rebuild on the tailwheel last night. It now looks more scale like, and works well too. I thinkk that I'll stay with this iteration. I'll post some pics tonight.
Bill, AMA 4720
WACO Brotherhood #1
Bill, AMA 4720
WACO Brotherhood #1
#1704
RE: WACO YMF
Well, figured out my choke access problem, no need for another hole in the cowl. I used a nose wheel steering arm and trimmed it, placed it on the choke stub shaft at the front of the carb. It barely clears one of the dummy cylinders; all I have to do is hook a finger inside the cowl and flick the "lever" to open or close the choke. Thankfully I won't have to do this while the prop is spinning. The choke has a detent that keeps it open, I don't have to worry about the lever vibrating and closing the choke in flight.
Here are some pics of the engine installation (G-26) and the inside of the cowl showing how I attached the dummy. It ain't the purtiest workmanship, but it's on the side you'll never see anyway. All the holes are to allow the expoxy to penetrate the lite ply, there are holes in the backs of the cylinders too. I used milled fiberglass in the epoxy for a stronger bond, and then fiberglassed the whole backside of the assembly. Lord knows I shouldn't need much nose weight. The ring that holds the cowl to the fuse had to be cut for clearance for the muffler and carb, but the remaining screws hold it very well, with no flex. I also added another layer of fiberglass to the inside and outside edges of the ring, and another layer to the bottom of the cowl to stiffen it where it passes along the muffler.
Long day at work, don't think I'll do more today, just act like a retired Navy Master Chief and slack off, surf the forums, and irritate beginners about decals[sm=48_48.gif]
#1705
RE: WACO YMF
As promised, here is the latest tailwheel. Thanks to Ken and others (I stole his design)(kind of - sort of) but as I said, I think it will suffice.
Bill, AMA 4720
WACO Brotherhood #1
Bill, AMA 4720
WACO Brotherhood #1
#1706
RE: WACO YMF
Ken,
Have you put the cowl on the scale? Wonder how much it weighs? Which dummy engine did you use? Sorry about all the questions, but I'm contemplating having to make one for mine, and I was just wondering.
About that decal thing....Why wouldn't they want it to look like an ARF? After all, it is one..[:-]
Bill, AMA 4720
WACO Brotherhood #1
ps...I will be absent from the forum for a few days. We are flying out to Sunny California on Thursday for the Baby Daughter's wedding. Back on Monday. I think that I'll be pretty busy for the next 6 or so weeks, what with the Wedding, and then going down to Lakeland for the meetings associated with Top Gun. I have the feeling that Frankie T. will be wanting some time from us prior to the event.
Bill
Bill, AMA 4720
WACO Brotherhood #1
Bill
#1707
RE: WACO YMF
ORIGINAL: Stickbuilder
ps...I will be absent from the forum for a few days. Bill
Aahhhh, finally..... some peace and quiet
Sounds like you'll have a great time. Congrats to you and your daughter. Mine won't be ready for several more years, I hope. (9 and 14)
I never thought of weighing the darn thing, duh-uh. On my trusty and I-don't know-just-how-accurate spring type postal scale, it comes in (completed cowl/dummy engine) at one pound exactly. Probably pretty close. The dummy I used is from Aerotec, the only place I found a decent looking 7 cylinder dummy. It wasn't cheap, and is pretty basic, but has potential. It's made from some kind of resin.
As for the ARF thing, I'm doing my damndest to keep it from looking like everybody else's ARF
Blue Skies and Fair Winds on your voyage to the Granola Bowl (Cal.) and back.
#1708
RE: WACO YMF
ORIGINAL: khodges
Bill, AMA 4720
WACO Brotherhood #1
#1709
RE: WACO YMF
There are 5 kids in all from 40 through 25, ...............................So, now I can start thinking about retirement.
Bill, AMA 4720
WACO Brotherhood #1
Bill, AMA 4720
WACO Brotherhood #1
Hey, maybe you want to take up model airplanes when you retire, great hobby.
#1710
RE: WACO YMF
ORIGINAL: khodges
Bill, AMA 4720
WACO Brotherhood #1
#1712
WI
RE: WACO YMF
Looking for graphics for 1/4 scale waco. I bought a set from Cajun RC, very nice quality, but not quite the right scale. Are there any other suppliers out there?
#1713
AZ
RE: WACO YMF
Jacque,
Try this for AeroTech Models http://www.aerotechmodels.com The Dummy Radials are one the left (the pictures are a bit fuzzy). 1/6th scale are the 6-3/4", 1/5th scale are the 8". Good Luck
I fixed the link .
I fixed the link .
#1715
RE: WACO YMF
Nightstalker, You old chicken thief...
Just when I thought you were gone from the forum, you pop back up again. I'll try to return the favor when I fly over Arizona tonight.[sm=lol.gif] Talk to you guys in a few days.
Bill, AMA 4720
WACO Brotherhood #1
Don't give Ken too much grief while I'm gone.
Bill, AMA 4720
WACO Brotherhood #1
#1716
RE: WACO YMF
Try this one also: www.aerotecmodels.com/dummy.htm
I couldn't get Nightskulker, er.... Stalker's or Sklarrkmk1's link to come up.
Well, I tried it and this one doesn't even work, although I can pull the exact same address off my favorites list and it goes right to it. Just try entering the address manually and see if it works.
#1718
AZ
RE: WACO YMF
Bill, AMA 4720
WACO Brotherhood #1
Bill, AMA 4720
WACO Brotherhood #1
Us mess with a Lt....? Naaaa
Nightstalker
Doggie 47
#1719
RE: WACO YMF
ORIGINAL: Nightstalker
And your sheep are LIARS!!!!
Well, I couldn't stand it any more, I had to see her "naked", plus I wanted to get an idea whether she was gonna be a feather or an anvil. With everything in her except the smoke pump, control rods and covering/paint, she weighs 14-1/2 pounds, not too bad. She balances just a bit nose heavy at the recommended c/g point, which is 6 inches behind the top leading edge. I have some sheeting to do forward, and the tank detail on the top wing, but I think with the covering and paint, the balance will shift aft some. It will be close.
I decided on colors, and bought the paint. I'm using Krylon cherry red and a color called buttercream, it's a sort of light pastel yellow. The scheme below is what I'm going to do her in; the dark in the picture will be the red:
#1720
AZ
RE: WACO YMF
[quote]ORIGINAL: khodges
That's what I said... They drop me off into Bill's barnyard to fix a broke barn roof... and there's these chickens...mmmm... tasty... fried... with fresh corn on the cobb... from my Chinook's landing gear... so I'm gatherin' up tin scraps... and there she was... Bill, I swear!!! She liked the Nomex flight suit... She hit on me first... and said I looked handsome. ARMY fliers never here that... 'twas a moment of weakness... Dang you Lt!!! I was gonna be nice (Sir).
On a serious note (for a change... for now [>:]) Good looking pics... for an Air Force guy.
Out Here,
Nightstalker
Doggie 47
#1721
RE: WACO YMF
To the WACO Brotherhood.
Williams 1/6 scale radial on eBay
Pratt & Whitney 1/6 scale WASP RADIAL ENGINE MODEL!!!
Item number: 330100501089
Hope somebody wants it, I am not the seller, besides I already have one.
Be quick, recently found it, maybe a day left, age related forgot!
WACO Brotherhood No. I4.
old git - - - - - - - - aka John L.
#1722
RE: WACO YMF
Gets kinda dark and quiet around here with the Master Chief on shore leave. I just about had to do a search to find the thread
Before I disassembled the framework to start covering, I levelled the plane up so that the H stab was at 0 incidence, and checked the wings. Both are dead on at minus 0.5 degrees. Eyeballing the fuse it does look slightly nose down, but I think it's just the curve of the forward fuse that makes it look that way. The prop is exactly vertical.
Not sure what all this will translate to when I try to fly it, but my guess is it will fly fine. Right to left everything is the same, no discernable twist in the wings; I checked incidence at every other rib from the center out, top and bottom. I also mounted the wheel pants and adjusted their angle and fit the wheels. To make the Robart wheels snug on the off-size axle diameters, I cut an insert from brass to fit over the axle and into the hole on the wheel hub. It doesn't fit snug on the axle either, so I'll use some silicone to glue it in place, so I can remove it if necessary. The wheel pants gear struts and the cowl have been sanded with 320 grit to prepare them for a coat or two of primer.
I may actually start covering tomorrow.
#1723
RE: WACO YMF
Hey John L (old git),
The dummy 8" radials from Aerotech are the same price ($60) and have the correct number of cylinders (7) available to simulate the Jacobs or Continental engines than the one on ebay (Williams Bros., P&W 9 cyl, $60 at last check). They may not be as detailed (a more generic cylinder) as the W.Bros, but being solid resin, should hold up better than the hollow styrene (I believe) that Williams Bros. uses. The WB kits do make up into a very good looking shelf (display) model.
Ken - We should let the Master Chief enjoy his leave with his daughters marriage. We can't help him liking to play with the big water toys. From a Retired USAF Master Sergeant
#1724
RE: WACO YMF
ORIGINAL: skylarkmk1
The dummy 8" radials from Aerotech are the same price ($60) and have the correct number of cylinders (7) available to simulate the Jacobs or Continental engines than the one on ebay - - -
I didn't recognise the significant differences between the motors (didn't look). I did know that the Williams are becoming rare.
I've been enjoying observation of this thread and both learning and collecting items about the different flavours of Waco, how they are built and even their builders.
I don't know of a source of Aerotech replicas, are they still made?
old git - - - - - - - aka John L.
WACO Botherhood No. 14.
#1725
RE: WACO YMF
John L.,
See post 1714, the link is there (and it does work now).
Some of Williams Bros products are being manufactured now under a new company. Here is the link http://www.williamsbrothersmodelproducts.com/ . I don't believe they have a Jacobs or Continental engine kit (yet?) but they do have the P&W Wasp and Wright engines and cyliders. Also a paper on scratch building a crankcase.
